Question about Memorex Televison & Video
I recently got cable and all of my high defenition channels are not coming in.i need to know how to wire the tv to my cable and dvd player.i have a memorex flat screen hd tv
  • 126 Answers
Have you done a new channel search since you got cable? The best cable to use for high def is an HDMI, but make sure your cable box, dvd player, and tv have the correct plug.
Posted on Nov 19, 2009
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I don't know what channel to go to to be able to play my dvd player
where did you hooked up the connector wire coming from the dvd player, in the component input or at the RF jack of the tuner of the tv?. if you plug at the component input of the tv you will select AV1 or AV2 etc. in the settings. but if you hooked up into the RF jack you can select channel 3 in the tv but at this time you need to have manual tuned in the tv to get the signal coming from the dvd player or xbox.
Oct 13, 2012 | Emerson LC320EM9 32 in. LCD HDTV
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Hooking up to a sony tv need to know were the wires go and is there any set ups to be done
cables go from dvd player/vcr OUTPUTS to tv's INPUTS,
Then turn tv to Input or AV channel and you should be good.
Apr 19, 2010 | Hitachi 168589 DVD Player/VCR
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
Digital TV
right hdtv stands for high definitian tv witch basically means if you buy a hd dvd player or blueray then you can watch the films in really high quality alot better than normal dvd. The same if you had cable tv or sky you pay a fee for an hd converter then this lets you watch certain channels in high def. So it basically means that your telly is capable of using all the new hd equipment thats coming out like the playstation 3 can play high def dvd's as long as you buy the hd lead as you need this due to the fact that it sends more data to the telly their for giving alot better sound quality and alot better piture quality when watching hd dvd's.
At the moment their are only a few tv channels that are using hd at the moment but this will soon change.
So to watch hd dvd youll need an hd dvd player and to watch hd tv you need to contact your cable or sky people and ask them what you need to do to watch hd programmes. they will then upgrade your box and should send you an hd lead to plug into your telly from the sky or cable box.
Hope this is helpfull and easy to understand.
Hd is well worth having as the quality is amazing you wont believe it till you try it i was shocked as the detail and quality is mind blowing its like watching real life, it really is that good.
Let me know if you need further assistance ok
May 14, 2008 | Sylvania 6427TE 27" TV
Channel
You should have an input or source button on your tv remote control. Turn on your dvd player and press this button ( changing source from tv/cable to whichever video input your dvd player is plugged into ) until you get the dvd picture.
Peter
Oct 13, 2007 | NexxTech (DR30G0) System
Ilo dvd player wont search high channels
At a guess the device will only find channels it can detect. So what is your connection antenna or cable If antenna then all TV is line of sight and directional If cable - only the channel's the cable co supply will come down the wire.
Sep 17, 2007 | iLO DVDRH04 DVD Recorder
Televison & Video Logo
51 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
