Question about Samsung SGH-D600 Cellular Phone
No ring tone for incoming calls.
If i turn off 'quiet mode' the only other option is 'mute' Incoming calls only activate 'virbration'.
  • 83 Answers
Go to settings then to profiles the edit an it is on there if its nt there go to sound/phone settings
Posted on Jan 17, 2008
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How can i activate my ringtone
hi....
please follow these steps to activate you ring tone.
1.open menu--->profile---->select the profile which you are using currently
2.After selecting the profile---->select personalise from it.
3.there is an option in it,Incoming call alert
4.In that you have to select ringing to activate the ring tone.
5.There is an option called as Ringing tone,you can select which ever ring tone you want and save the changes.
thanx
Jul 18, 2010 | Nokia N73 Cellular Phone
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
How to turn vibrate on?
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone
, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Jan 16, 2008 | Nokia 6288 Cellular Phone
Samsung SGH-D600 Cellular Phone Logo
127 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
