Question about Electrolux Kitchen Ranges
Frigidaire electric range, Gallery series, Model PGLEF 385CS1 , THE OVEN DONT WORK ,, PUSH BAKE OR CONVECTION BUTTON , INSERT THE TEMPERATURE, START, THE CONVECTION FAN START ,BUT BOTH OF THE ELEMENTS DOESN`T WORK ???. I CHECK BOT ELEMENT WHIT MY TESTER, EVERYTHING IS O.K. PHONE A MY REPAIR DEALER AND HE ASKED TO ME , YOUR CONTROL WAS DOWN, BUY A NEW ONE (200-300$) . I LOST MY OWNER MANUEL TO TROUBLESHOOTING WITH ELECTRIC DIAGHRAM . cAN YOU HELP ME ??.
  • 464 Answers
Frigidaire electric range, Gallery series, Model - 250Here is the wiring schematic, hope this helps.
Posted on Nov 19, 2009
Testimonial: "Thank s , we appreciate."
Self cleaning mode had failure. Cleared by flipping breaker. Now runs bake/ convection mode with broiler at 600 + degrees and lower oven operates under temperature. I think temperature sensor error
Hello Pamela, thanks for your post!
From my understanding your Frigidaire range had an issue when it was in self-cleaning mode. It sounds like your thermostat or control panel may need to be replaced. I would suggest seeking help from a professional technician this will help you to avoid any unnecessary part purchases or improper disassembly of your range. Hopefully this information is helpful to you. -Matt
Jan 03, 2016 | Frigidaire FGES3045KF Gallery 30" Slide-In...
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Frigidaire PLEB30S8CCA baking element not working
Good Morning Jane, thank you for your post!
From what you have described, it sounds like you possibly have problem with a faulty thermal fuse, power supply board, user interface board or a communication error with the EOC (Electronic Oven Control). This is not a typical do it yourself job. Please reach out to an expert technician to ensure the appropriate replacement part(s) is ordered and is installed correctly to prevent future issues.
Best regards!
Feb 10, 2014 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
How to set the oven timer?
To Program Oven for a Delayed Start Time and to Shut-Off Automatically 1. Be sure that the clock shows the correct time of day. 2. Place the food in the oven. 3. Push "Bake Time". "00:00" and the words "BAKE TIME" will glow in the display window. 4. Push and hold up or down arrows until the desired baking time appears in the display. 5. After the bake time has been set, "----°" will appear in the display and the word "BAKE" will flash. The display will flash and beep once until the oven temperature has been set. 6. Push "Stop time". The time when baking will stop, will appear in the display window. The words "BAKE STOP TIME" will glow in the display. 7. Push and hold up or down arrows until the time that you want cooking to be completed appears in the display. 8. Push Bake (or Conv). "---°" will appear, and the word "BAKE" will glow in the display. 9. Push and hold up or down arrows until the desired baking temperature appears in the display. 10. If the baking temperature is not set, the control will beep. "---°" will flash and the word "BAKE" will appear in the display.
Mar 11, 2009 | Electrolux Kitchen Ranges
Kitchen Ranges Logo
342 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
