Picture is a mess words look like looking through a coke a bottle bottom, with a curve to the whole picture colors are seperating
  • 3,866 Answers
This is a convergence issue this will need to be repaired its is common with age and can be repaired you looking aroung $50 bucks to have this done Tv needs to be opened up there is little pieces of magnet type substance that helps with convergence on the back of the tube this will need to be evaled and replaced.
Thanks and please leave postive ratings and feedback for your free answer today!
Posted on Nov 19, 2009
How to fix the color alinements
You need to replace the two STK-392-560 CHIPS THIS SET USES AND DO NOT RUN THE SET WITH CONVERGENCE BOWED or soon you will have other parts bad.
May 27, 2012 | Sony KP-57HW40 57" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Colors seperating and out ends of screen curved
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 27, 2010 | Mitsubishi WS-55809 55" Rear Projection...
ALL 3 COLORS ARE SEPERATED AND CONVERGANCE DOES NOT FIX
We fixed this same problem as a dyi project. Check out www.tvrepairkits.com. The kit itself come with the proper chips, fuses, and very detailed instructions which includes pictures. They also have online help if you have questions. If you know how to solder and are a very careful person, this is something that you can fix yourself.
Mar 08, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pink and green colors seperated images rounded off
If colors are skewed and will not adjust in the customer menu---you have a CONVERGENCE circuit problem.
This model (KP-51WS500) uses two of the STK-392-560 convergence IC chips. I just got home from fixing a similar model with the same problem.
Parts cost on Ebay for the chips and such is going to be less than 30 dollars total. Shops are going to get 300 or more for this kind of repair---and some will not do it in your home---the repair takes about an hour--I have done hundreds of them here in people's homes.
If you have questions or need advice, reply to this posting and I will try to help.
If this told you something that helped you understand, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Sony KP-51WS500 51" Rear Projection...
52'' Projection TV SONY
this is a problem with the convergence chip. you can try to adjust the convergence in the menu settings of the t.v.
pin cushioning will correct the curves, convergence fixes color seperation.
write the number down before changing them, in case you make it worse.
Nov 11, 2009 | Sony Televison & Video
SONY PROJECTION TV MODEL # KP-51WS510.
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
jasbo
jasbo
