Question about Whirlpool Washing Machines
Spin cycle stopped working I can't find the model # Can anyone tell me where to look. It was purchased in 2001 or 2002 at AAFES. "Commercial Quality" 9 cycles, 4 speeds, Extra Large Capacity
  • 1 more comment
  • lizdebarr Nov 19, 2009
    Thank you, we will check it out. :)
    I found the part on ebay for $4.95 and no shipping. I ordered it. I found a video on YouTube, by a guy named ApplianceMike, explaining and showing exactly how to change it out step by step. I am going to try to fix it myself as soon as the part gets here.
  • lizdebarr Nov 28, 2009
    Well today we took the washer apart and replaced the direct drive coupler. Unfortunately this did not fix the problem. Fortunately this was an inexpensive investment. Still appreciate the suggestion from Sassy6.
  • 464 Answers
Lift the lid and look around the opening of the tub towards the back just under the cover. You may need to replace the direct drive coupler which is located on the motor shaft and is made up of 3 pieces. Not an expensive part and easy to repair if you are handy.
Posted on Nov 19, 2009
Testimonial: "I appreciate the prompt response. Haven't attempted the solution suggested yet, but definitely gives me a place to start and probable solution. A+"
My hoshizaki ice machine KM-900mrf model beeps 3 times and stop making ice. After reset it starts, but stats beeping again after an hour.
Have a look at the side of the evaporator; there is a probe (thermistor) attached to it that tells the control board when to initiate the harvest cycle. make sure it's clean and attached properly and doesn't need replacing. If hitting the float switch initiates the harvest cycle it sounds like you have a blocked/ scaled water tube or switch housing. take off the bottom of the switch assembly (black rubber bit) and clean through to the water chamber. run a cycle of descaler before trying again.
Jul 04, 2015 | Hoshizaki Freezer Commercial Ice Machines...
What can I do, just purchased a watch and is not working properly.
Honestly if it were me, I would simply return it to where it was purchased.
Also know that anything purchased via a credit card is usually protected.
You can call the credit card company and tell them the item is defective. They will ask if you have tried to remedy the situation with the seller, and go from there.
I hope you get your refund. God Bless and Thank you and your husband for your service.
Nov 13, 2014 | Watches
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
Hello I work for AAFES i am a damaged and defective clerk i had a customer return a defect GTP1010 the Po is 0055172271 s/n R61B382891W i need to know how i may get a return autherzation for the...
My question is: where does AAFES get its merchandise from? Since you have a PO, and obviously have a purchase date & packing slip, etc. My first recommendation would be to contact them. If that doesn't work (or they refuse to support your purchase) Then I would contact Samsung directly. Identify yourself as a retailer through AAFES and request support (replacement, Rreturn Merchandise Authorization (RMA), or whatever they want to do). I would also recommend acting quickly since the further out a damage/return gets from the purchase date the harder a claim is to prove.
The samsung warranty policy link is below:
http://www.samsung.com/levant/support/warranty/warrantyInformation.do?page=POLICY.WARRANTY
Good luck, and feel free to reply if you have further questions.
Aug 23, 2011 | Samsung Computers & Internet
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Filter? Is there a filter I should be cleaning out periodically?
There is no filter to clean in your machine.....any lint or other build up is designed to go out with the drain water...
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
