Question about Frigidaire Dryers
Frigidaire dryer model FSEC346RHS0 When I open the door the drum stops as it is suppose to but about 30 seconds later, while the ddoor is still open, the element starts to glow red.
Heating element had broken and was shorting out agaainst the frame causing it to get hot.
Posted on Nov 19, 2009
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Drum keeps spinning after dryer door is opened
What is the model number of the unit?
Nov 03, 2012 | Kenmore Dryers
Still turns after opening door
When the door is closed the switch will close, allowing power to circulate through the rest of the circuit. When the dryer door is open the switch will open, breaking electrical contact to the neutral connection of the circuit and stopping the flow of electricity. so it sounds like a bad dryer door switch.
Feb 02, 2012 | Frigidaire Dryers
I have an AEG 57560 condenser dryer.The unit start properly, turns well, changes rotation well, but stops sometimes after 10-30 seconds. When I restart the unit, sometimes it works well, sometimes it...
Check the door catch......mine was doing the same, and I noticed that the door catch was split slightly and the door was not completely closed. This meant that the dryer kept thinking the door was open and so automatically turned off. Now all I need to do is find the replacement part!!
Hope this helps.
Nov 13, 2010 | Dryers
Dryer stooped working suddenly.
Replace the fan belt that turns the dryer drum. Use only the genuine replacement spare part for your dryer.
Jun 07, 2010 | Frigidaire GLER331A Electric Dryer
Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
Jun 06, 2010 | Frigidaire FEQ1442ES Electric Dryer
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
Frigidaire dryer drum liner
yeah, i think there called "drum glides" www.partselect.com type in your model number and you if they have that dryer in the system, then breakdown of the dryer will show, multiple diagrams. And look for the glides that are supposed to go there...hopefully this helps
Jul 31, 2009 | Dryers
Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Dryers Logo
128 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
