Question about Sony Cyber-shot DSC-W50 Digital Camera
C:13:01 Error Sony dsc-w50
Hi! c:13:01 error is blinking on my camera.. can you help me solved my problem?
  • pokloy Jan 10, 2008
    needed immediately..!
  • nechon May 31, 2008
    hi c:13:01 is blocking my camera, and i can`t format because i need the pics.
  • 589 Answers
Theres something wrong with the memory stick / card. See if the little "lock" tab on the card itself is in the unlocked position. The card may be bad too.
Posted on Jan 11, 2008
Need manual for dsc-w50 camera
Most of the documentation for the Sony CyberShot DSC-W50 is available on the product support page: https://esupport.sony.com/US/p/model-home.pl?mdl=DSCW50&template_id=1®ion_id=1&tab=manuals#/manualsTab . Make sure to look at the Manuals tab. Scroll down for the User Guide. The direct link to the manual appeared as https://docs.sony.com/release//DSCW30-W40-W50-W70.pdf in my browser history.
I hope this helps.
Jul 14, 2018 | Cameras
I have an E91-01 error message which will not correct itself after reinitialising. How can I solve this? The camera is a Sony DSC W50. Thanks
Hello and welcome to FixYa!
To solve the error E91-01 error, Please follow the instructions given below:-
  • Turn the camera OFF
  • Remove the battery or the power supply
  • Turn the switch to CAMERA for about 30 sec
  • Turn the switch to OFF
  • Install the battery or power supply
  • Turn the switch to MEMORY
  • Open the LCD cover and press the RESET button ( small inner button )
  • You will be prompt to adjust date/time. Do it
  • Now Take some pictures
Error will be removed, If still occur, Perform the above steps once more, after it if still error prompts then it means that service is required by authorized service and they should change the flash unit, In this case go to authorized SONY Cameras service provider, Your problem will be solved.
I hope this solution helps you
If you have any more Confusion, questions or issue regarding your problem do inform me.
Thank you for using FixYa!
May 14, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
ERROR CODE 91.01
this is my same problem in my Sony Cyber-shot DSC-W130., pls e mail me if someone answer your problem., this is my e add -- helterbrand_16@yahoo.com ur.goingdown@ymail.com
thanks.pls..
Dec 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at toms.safranovs@gmail.com or contact your local Sony service center.
I work in a Sony service center.
Tom
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I get an error message, E:91:01 blinking ,I can't find Reset bottom under LCD cover
Hi!
It's flash error. Could be a dead flash fuse on the main board or bad flash board. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 12, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
I've had my dsc w50 for about 2.5yrs and its just started the same milarky! Go to menu, set up 1 and re-initialise, it cleared for me then came back again. Went through the same process just now and error has gone for time being, although I think the flash is on its way to heaven. Some pictures are dark and others completely white out!!
Taking it in to the sony shop tomorrow to see if they can lend any advice - I hope it doesn't mean a new camera as I've not over used it....
Let me know how you get on
Dec 03, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
Jul 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
E91:01 Error - DSC-W50
error E:91:01
Reset the setting,on the clock set menu turn off the camera then remove the memory card and open the camera now reset the settings now you will get back your flash
Dec 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
290 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
