Question about Brother LS2020 Sewing Machine
Trying to use and bobbin keeps tangling up with loads of thread
  • 776 Answers
Oil the bobbin holder. Wipe small amount of oil on outside diameter of bobbin holder. Replace.
Also try using better quality thread. Some thread is not consistent in diameter or has lots of small fibers - it will not got through the eye of the needle easily and will become tangled.
Posted on Nov 19, 2009
Bobbin keeps tangling with to thread
Have you checked your tension? And is your needle an old one, or bent or blunt? Are you sure it is threaded correctly? Is it the same thread in the bobbin as well as top> Is the needle the thickness used for the material you are sewing>
Best wishes.
Dec 23, 2014 | Euro-Pro Sewing Machines
Thread keeps getting tangled in bobbon and wont sew
try changing the needle
rethread using EVERY thread guide
make sure the thread has not come off the thread take up lever
make sure the bobbin is inserted the right way--counter clockwise
make sure the bobbin case is inserted correctly if it's a side or front loading bobbin
clean in the bobbin area and under the needle plate
Dec 15, 2014 | Sewing Machines
Thread tangling inside bobbin case catching on another part
1. thread machine correctly.
2. make sure bobbin case in spinning in the case in the correct rotation. If the bobbin is spinning off of the bobbin incorrectly, "bird nesting" is the result.
Jul 20, 2014 | Brother NX-400
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
How do i put threed into the bobbin and keep it from not getting tangled?
Is it getting tangled while you're spooling the bobbin on the top right corner of the Singer 1507 machine? If this is the case, you have to pull the thread through the top tiny hole in the bobbin, and hold on to the thread end. Then click the bobbin to the right to lock it in place, power up your machine. Keep holding the thread as you begin spooling the bobbin. Let go of the thread once the bobbin starts to spin a few rounds and the thread should not get tangled.
Sep 29, 2010 | Singer 1507
I've tried everything that other users have suggested, but the thread keeps gathering immediately in the bobbin case. What should I do?
It has to be in the threading, either your thread is tangled, or incompatible with your bobbin thread. How is your needle?
Is the thread that is tangling from the bobbin? If, so you have your bobbin inserted upside down and the thread is not unwinding right. If, all that does not work, call Janome at 1-800-631-0183 before 5pm est
Sep 17, 2010 | Janome Thread Banger TB12 Sewing Machine
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Bobbin tangling
Sounds like the bobbin is spinning to fast or is winded to loose. Try adjusting the tension on the bobbin.
May 05, 2009 | Sewing Machines
Bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Brother LS2020 Sewing Machine Logo
207 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
