Question about Sony CDP-C265 CD Player
Broken carouself? Can't properly open, close, rotate, etc.
This problem may be irreparable. The problem I had been having was that the carousel would occasionally get stuck halfway to closing. If I fiddled (turned it off and on, manually pushed on the changer, pulled open, etc), I could get it to work. This last time, I must have pushed on the rotating part of the carousel too hard, and it wouldn't push smoothly anymore (instead of the smooth noise, it just clicks, and pushes loosely). Now it perpetually tries to open and close, struggles to rotate, struggles to open and close (can't without assistance). It doesn't ever seem to actually lock into a position, lock into open or closed, etc. I took it apart (not extensively), couldn't solve the problem, put it back together, and didn't accomplish anything. One small piece (a white plastic bit, not sure from where in the machine) broke off.
    President:
  • Sony Master
  • 1,114 Answers
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Posted on Nov 19, 2009
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Posted on Jan 24, 2010
  • Anonymous Nov 22, 2015
    Thanks! This worked for me, but only one "clunk" needed.
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Jul 16, 2010 | Dell 3010cn Laser Printer
CD carousel won't rotate. Opens and closes fine, but will not change discs in either the open or closed position.
gears may have something obstructing them. Check and clean with dustaway. Gears may be broken jammed or slipping belt.
Apr 06, 2010 | Denon DCM-360 5-Disc CD Changer
Service required E527
E527 indicates a developer home position error. With the front cover closed you should be able to freely rotate the cartridge "carousel" from the top with the PCU removed. If it does not rotate smoothly then something is broken and the printer will require stripping completely and the broken parts replaced. If this is the case then it is unlikely to be economically repairable. If the carousel does rotate freely however, then it is one of the following: Either the MCU (engine) Board itself is faulty, there is a wiring fault or the Sensor Rotary Home Position is faulty/dirty. The sensor is the first and most obvious thing to check but it requires taking off the L/H cover and removing the Low/High Voltage power supply board to get at it. I would recommend getting someone experienced at repairing printers to do this, but if you really want to give it a go then follow this link;
http://www.fixya.com/support/t1865287-epson_c1100_service_req_e527
Jul 27, 2009 | Epson Aculaser C1100 Printer
Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
DRUM Q3964A FOR HP 2840
10.000x Supply error Description E-label can’t be read or print cartridge is not properly installed. Solution
  1. Reinstall print cartridge.
  2. Power cycle device.
  3. If the problem is not solved, replace the cartridge. NOTE: The software CD-ROM that came with the HP Color LaserJet 2820/2830/2840 all-one includes an animated tutorial that shows how to replace the print cartridges.
    1. Remove any media from the ADF, and then push the scanner-release button to open the scanner assembly.
    2. Open the cartridge door.
    3. Make sure that the correct print-cartridge slot is in the access position.
      • If the correct print-cartridge slot is not in the access position, close the top cover and the scanner assembly, and then press ROTATE CAROUSEL until the correct print-cartridge slot is in the correct position. Pinch together the two large blue tabs on the first cartridge, and then lift the cartridge straight up to remove it from the carousel.
    4. Remove the new print cartridge from its packaging, remove the orange cover from the print cartridge, and then pull the orange tab straight out to remove the sealing tape.
    5. Squeeze the blue release levers on the print cartridge, holding it with the roller facing you. Lower the cartridge straight down into the carousel until it is firmly in place.
      • To replace another cartridge, close the top cover and the scanner assembly, press ROTATE CAROUSEL , and then repeat the previous steps. NOTE: If a black print cartridge was replaced, then the device prompts to have a cleaning page ran, unless the device page count is less than 100 pages.
    6. Close the top cover, and then close the scanner assembly.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00414128
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 05, 2008 | HP LaserJet 2840 All-In-One Printer
Replaced toner but keeps saying replace supply using black only
This happens occasionally with after-market (refurbished) cartridges. Sometimes the people rebuilding the cartridges forget to replace the microchip on the cartridge that resets the copy counter. Most reputable re-manufacturers will send you a replacement cartridge if this happens.
It could also be a carousel alignment or sensor issue inside the printer - if this is the case you will have to call HP for service.
Whatever you do, make sure you do not try to manually rotate the carousel to change out the different cartridges - each time you want to change a specific color, close up the printer first and then press the carousel rotate button that's directly under the ready light, keep pressing until the display says that it's rotating to the color you want, then open and change that color, repeat for each additional color.
Oct 13, 2008 | HP LaserJet 2840 Printer
Black toner replacement will not go into machine
If you cannot install the toner on the a cover
try this solution
close cover a
turn off the printer
open cover b remove the pcu rotate the carousel when the specific toner that you want to replace facing the cover f remove the old toner and replace it with he new one. you will know that the toner is properly placed if the carousel is rotating freely
Oct 02, 2008 | Epson ACULASER CX11NF All-In-One Printer
Looking for a repair facility
At the cover that you opened to access the toner drum carousel, there should be a hole where a plastic fin pokes when the cover is closed. Generally you can use a screw driver to depress this and it will allow the carosel to turn freely so you can remove all the toners.
  1. Close the door after all cartridges are removed and power the printer up again, it should ask you to reinstall the cartridges 1 by 1.
  2. I don't think you broke anything unless you used alot of force to turn the carosel, that noise is quite common if you turn it without that tab depessed.
  3. It's likely that one of the toners is not seated properly causing this issue...
  4. Hope this helps...
Jul 31, 2008 | Konica Minolta magicolor 2430 DL Laser...
Sony CDP-C265 CD Player Logo
1,216 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
