Question about Grohe Home
I just installed body sprays in my shower. Two on one side and two on the other. I went to the basement to turn the water back on. I came back to the shower and one side of body sprays are running, the other is not. I turn the knob (volume control) and that only increased the water pressure. I tried the other side and all is good. I took the handle off to see if the actual copper colored hub was off or something but I cannot figure it out. All the other handles shut the water off but this one baffles me. Everything was hooked up in the house before I moved in except the body sprays but the fixtures were there for me just to add them which I did. So, what am I doing wrong?
  • 5,603 Answers
If the sprays are on individual controls for the sides you MAY have a stuck pressure balancing valve or mor likely the service stop valves MAY be closed. These are small screwdriver controlled valves usually behind the escutcheon of the control valve. They turn CCW to open.
Posted on Nov 19, 2009
My shower head comes on all the time
two possible causes. 1- make sure the valve body is installed with with shower mark on the valve body facing up. 2 - if you used pex pipe and fittings to stub out for the tub spout this will restrict the flow sending water to the shower, '' change out pex pipe and replace with copper or galvanized pipe
Apr 06, 2014 | Globe Union Glacier Bay 8 In Double Handle...
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
I need troubleshooting help with my three function transfer shower valve .
valve is bleeding by remove and check the condition of cartrige look for wear or dirt
Apr 28, 2012 | Home
Jsut installed a tuscany Asti Tub and Shower Faucet, when the mixer handle is centered and you are running thru tub spout, water still comes out of shower pipe. it does not do this if solely set to hot or...
Check the valve body to make sure it is right side up. there will be a marking on the valve that tells witch is to go to the tub spout and witch to the shower head. If you have it right then you will need to disassemble the valve body and look for debris in the cartridge.
Feb 11, 2011 | Ldr Industries Home
Went to change the handle in my shower when putting it back together it wont shut off water runs even while turned off.
try taking handle off and shut off water from stem..nall inside body may have turned>>once off install handle at point where it goes in
Nov 22, 2010 | Delta Plumbing
The faucet leaks, behind the wall when the shower
The most common reason for basement leakage is from the seal at the drain or the seal behind the overflow. With the overflow, the water trickles down after bouncing off your body and back onto the tub. This possibility MUST be eliminated first before determining the next step, Turn on the cold water and fill the tub and let the water go into the overflow for about 5 minutes. This will simulate someone in and using the shower. Check for leaks in the basement.
This test, as simple as it is, will also implicate bad plumbing connections at the valve itself behind the wall as well as eliminate backsplash from the showerer bouncing back onto your control valve(s).
If you have a leakage, wait a day and, with the drain open, turn on the hot/cold valve(s). and waste some water for another 5 minute test. This test eliminates the overflow as a suspect, and with the drain open almost always eliminates the drain as well. Hey..in plumbing there are no perfect answers.
If you still have leakage and no one is showering you have pretty well isolated the valve or connections to the valve. If you don't have leakage, it points to water bouncing off the body and onto the control valve(s) at which point resealing would be in order.
You can get leakage also if the caulking around the tub where the tub meets the wall has gone south. Stamped out steel tubs (common in rental apartments) have open corners so if the wall-to tub caulking is poor then the shower bounce off the body will easily trickle to the basement. This is not an issue with cast iron or fiberglass/plastic tubs.
If these tests truely point to the valve(s), repost your ? and refer to the drain tests completed, and supply as much information as you can about the brand and age of your valve(s)
Jun 02, 2010 | Moen & One Handle Tub & Shower Faucet
Tried to install a one handle delta shower fixture. Water comes on but will not shut off.
Try taking the handle back off, and turning the water back on. Spin the valve stem and see if you can find the off position that way. Hope this helps
Aug 16, 2009 | Delta & Single Handle Shower Faucet
Shower body three way diverter problem, no water to one port
try taking the shower head off and see if there is something stuck in it. sometimes things will come through the water lines and lodge themselves in the valves as well. if the shower head isn't clogged try dismantling the valve that turns the shower head on and then turn the water on when its out and flush the port out.
Jun 11, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Shower handle leak
turn off main water in home . turn on tap some where in home to release presser take shower handle off (screw under cap) unscrew the tap with a wrench unscrew on insides you pull out replace washer put all back togethere
Feb 11, 2009 | American Standard 3275.505.099 Colony Soft...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
128 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
