Question about HP iPAQ HX4700 Pocket PC
Cannot get past opening screen or turn off unit. Unit seems frozen
I was connecting to wi fi when unit turned off. I turned it back on but it cut off again shortly. Another attmept to turn it on resulted in the blue Hp iPaq screen coming on but nothing further. I cannot turn it off, get past this page. I disconnected battery for short time. Same result. Disconnect several minutes. Same result. Plugged into ac charger, usb port on laptop. same result. The battery locks are secure, battery charged.
Did soft reset and hard reset but no help.
  • 11 more comments
  • johnmoses Jan 11, 2008
    Nitrotrike,
    It did have a Sandisk 2 GB card in it when it went down, I took it out and tried as well, same problem.
    OS is WM2003
    Don't mean to sound stupid, but I downloaded the updates you suggested to laptop. Cannot Sync with 4700 to send the updates there.
    I do have Activesync and was using it daily before this problem occurred. Since the pda froze I cannot sync with the laptop. It does not find the device. By the way, I really appreciate your help. I am going out of town this weekend on business and was really counting on using this pda. (I did grab the beer)
    I tried this link but no good. I was able to sync up thru this morn. The problem now is that the pda is locked/frozen and will not go past HP page. I cannot make it sync because it is unresponsive.
    Otacon,
    I downloaded the BIOS and also ROM (?) onto laptop. The problem is that the pda is frozen.I cannot make it reset, sync, download etc. The only functions I can perform are; doing a soft reset turns screen on in subdued grey but only displays HP iPaq screen. If I hard reset I get this same screen but in color. The power button will turn screen on in grey, but will not power off. The Flash mode series resulted in the screen powering up and then powering off when I release the buttons.
    I did get some reaction here. At the top of the screen it offers:
    boot options;
    enable kitl no (this line is highlighted)
    clean registry hive no (not highlighted)
    format storage no (not highlighted
    Touching any of these does not get any reaction
    Don't know if it makes a diffrence or not, but I do not have a cradle. I am conection thru USB to pda direct.
    I was able to press 4buttons and have device turn off. I then connected with USB cable and proceeded with the rest of the process. When it tried to run the BIOS on the pda, the message was given that it was not connected thru activesync. I tried to connect to activesync, but it would not locate the pda.
    Questions: How do I know if I am actually in flash mode?
    Why would it matter if it is a cradle or cable? They both serve as a power source and data transfer correct?
    I was also able to push 4 buttons, get bright blue screen with the above options. I was able to toggle by using the ITask button and the calendar button to turn all otions on. Then I can't get it to do anything else. I tried a soft reset and simply got the HP page in subdued grey.
  • johnmoses Jan 12, 2008
    After following the previous suggestions, I still cannot connect the pda to laptop to download the new updates
    Sweet Rascal, How do you recommend restoring factory settings? Please explain in steps.
    It seems to be at a stand still here, but I still need help.
    Hard reset was done 2 days ago. I appreciate your help, but please read what has already been done. This pda is locked and soft resets, hard resets dont change the screen. Flash mode resets change the screen (refer to above post about "boot options") but still don't allow me to connect the pda to the pc.I have downloaded the BIOS and ROM updates and tried to install them but the pda does not connect to the pc thru activsync because it is locked up.
    Scholar:
  • 64 Answers
If none of the reboots work and you still need to put it back to factory settings try removing or replacing the internal back up battery. I have provided a link which will show you step by step on how to accomplish this. GOOD LUCK! Sounds like you have tried every other option.
http://paulstravelpictures.com/HP-iPAQ-HX4700-PDA-Backup-Battery-Replacement-Guide/index.html
Posted on Jan 12, 2008
    Guru:
  • 1,894 Answers
Try to restore the factory settings.. this may help
  • dewan nafees ahmed Jan 12, 2008
    To do a hard-reset which is what you want, you press the two outter
    hardware buttons (Calendar and iTask), hold them down and poke the hole
    in the back with the stylus and hold it until the screen in the front
    completely fades to black, then release the buttons and poke the hole
    once more and you're set.
    also check out this link
    sorry john..
    after reading all the suggestions i can also come to the same conclusion that our friend otacon has arrived at..
    your ROM is the fault.. you will need to service the unit..
    sorry once again..
    thank you
    President:
  • 1,944 Answers
Did you try to flash the BIOS/firmware of your device?
1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
5.) Make sure your USB connection to the Cradle is hooked-up.
6.) Place your iPAQ in the USB Cradle.
7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
8.) Hilight WESCOMM.EXE and select "End Process" button.
9.) Run the file you downloaded from HP in step 3.
10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS
Posted on Jan 11, 2008
  • 3 more comments
  • Damen Wong
    Damen Wong Jan 11, 2008
    The link for the BIOS is here..
    http://h20000.www2.hp.com/bizsupport/Tec...
    The link I posted before doesn't work...sorry...
  • Damen Wong
    Pressing those four buttons doesn't put the device in flash mode...so as long as you hold it down it doesn't power off? Hmmm...get someone to help you and keep all those buttons pressed and put the device in the cradle and see if it connects.
  • Damen Wong
    So you press the four buttons and you get to a screen with options. And when you let go of the buttons, it turns off? I think the cradle is needed to flash the device.
  • Damen Wong
    Damen Wong Jan 12, 2008
    I am sorry but I suspect your unit's ROM has malfunctioned. You need to get the device serviced.
  • Damen Wong
    That is why it can't turn on or even be flashed. The device simply just can't access it due to it's malfunction (it can once in a while - since you said that you managed to sync once).
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
Wi-fi not obtaining IP address and if turn off wi-fi can not get to turn back on
Assuming you're trying to connect via wireless router. If you connect, but then aren't able to get to the Internet. I would something is wrong between the router to the modem to the wall (DSL/Cable modem) rather then your tablet device. You can connect your device to your router and you device will show it has a wifi connection, but beyond the router something may be amiss. Try seeing what you get from another device like computer or laptop. That might get you closer to your actual issue,
May 31, 2014 | Coby kyros Tablets & eReaders
Will not open web with wi-fi i turn on wi-fi device turn Wi-Fi back off
I would say that there is an issue with configuration or codes. Try opening the network and sharing centre and run the trouble shooting option.
Dec 11, 2013 | Computers & Internet
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
I HAVE A PANDIGITAL NOVEL AND CANNOT SEEM TO GET PAST THE WI-FI PART. IT SAYS THAT WI-FI IS ON, NOT CONNECTED. MY WI-FI IS LISTED AS THE NETWORK BUT FOR SOME REASON NOT CONNECTING. CONSEQUENTLY, NOTHING...
Some routers come preset with a network key, others can be manipulated. many have driver issues when dealing with newer Pc's
Are you getting internet through a wired connection from the router? or is this strictly a wi-fi issue?
Dec 15, 2010 | Computers & Internet
I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Feb 24, 2009 | Apple iPod touch
Connecting my i-touch to a Wi-Fi connection
Yup....you'll need a small router. I use a DLink WirelessB unit. Ask your local computer store for a small router, just an inexpensive unit. DLink or Linksys are the best. If you're uncomfortable trying to set up a home network, get the Geek Squad to do it for you. If you have any more questions, get back to me and I'll try to help more.
Jan 03, 2009 | Apple iPod touch
HP iPAQ 3715 - screen problems
Return it as faulty. WiFi should not impact your screens ability to stay on.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
294 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
