Question about Dell Dimension 4700 PC Desktop
Cannot access the box to replace RAM. Cannot find
Cannot access the box to replace RAM. Cannot find any buttons to release at all.
    Sergeant:
  • 267 Answers
Look in the back there are screws you will need to unscrew. a philips screwdriver should do the trick. the ram will be sitting on the motherboard in a slot with little release levers
Posted on Nov 19, 2009
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
Service manual link
http://supportapj.dell.com/support/edocs/systems/dim4700/sm/index.htm
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Where is the fuse box on a,98 Dodge RAM 1500
Leonard, interior fuse panel is open drivers door, at the end of dash driver side behind a small interior access panel, under hood fuse/relay center(box) is beside battery on inner fender.
Video links will show you fuse boxes location.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Interior Fuse Box Location 1994 2001 Dodge Ram 1500 1997 Dodge Ram 1500 5...
Dodge ram 1500 fuse box gone bad
Feb 29, 2016 | Dodge Cars & Trucks
How can i access my trunk in my 2006 impala if my battery is dead
Rear Compartment Lid Release
The rear compartment lid can be released by depressing the rear release button in the glove box or holding either front power door lock switch to the unlock position for a minimum of 2 seconds or by pressing the rear compartment release button on the key fob. The transmission must be in the PARK position for the rear compartment to release. No Key lock on the trunk ?
Dec 07, 2015 | 2006 Chevrolet Impala
How to remove RAM from compaq presario v3000?
1. Identify where RAM resides:
- On the front (you will either need to access the RAM memory by removing the front parts of the laptop (Keyboard, Touchpad etc)
- On the back ( usually a RAM memory door to unscrew)
2. After accessing RAM sockets, hold both metal prongs to the side. The RAM memory card will release from the motherboard.
3. Gently hold the ram card on a 45-degree angle and remove the card.
4. Install your new replacement RAM memory.
May 14, 2014 | HP Pavilion dv6000z Notebook
Install ram upgrade for acer aspire 5310 pc
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase or buy for working pairs if possible
Unplug your laptop from the AC power source and remove the battery.
Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
Locate the memory access door for the main memory module. It should be on the back of your computer.
Unscrew the memory access door and remove it.
Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
Align the new RAM module with the tab in the connector slot.
Slide it firmly into place and gently rotate it downward until it clicks into place.
Replace the memory access door.
Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use.
hope this helps
Aug 22, 2012 | Acer ASPIRE 5310 COMPATIBLE LAPTOP LCD...
I need to replace my ram memory in my computer
open ur atx cabinet box opposite side from the mother board
then release the lock both of side
and remove old ram then fix newone
u must see the lock
ur ram not properly coming beep sound
Jun 22, 2011 | MPC Computers ClientPro 365 PC Desktop
How do you get the paper inside that thing?
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
NOTE: If the issue is resolved, and you want to print on another type of paper, load the new paper type, and then repeat the previous steps for the new paper.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution four: Clean the paper rollers Follow these steps to clean the paper rollers.
  1. Press the Power button to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Different models have different rear access doors. Some have one release tab, some have two release tabs, some have a knob to turn, and some have in-tray catches. Some also have automatic two-sided printing accessories (duplexers). Release the rear access door or duplexer as necessary, and then remove it to access the paper rollers for cleaning. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif c00104514.gif Product with a rear access door release knob Product with in-tray catches c01964197.gif c02297019.gif Product with a duplexer c01964198.gif
  4. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward carefully to clean all the way around. Figure 1: Paper rollers
  5. Allow the rollers to dry completely, and then replace the rear access door or duplexer. Slide the rear access door or duplexer into place, and then gently push it in until it clicks or snaps into place.
  6. Reconnect the power cord to the rear of the product.
  7. Try printing again.
techbelkin.giftechbelkin_0.giftechbelkin_1.giftechbelkin_2.giftechbelkin_3.giftechbelkin_4.gif
Nov 02, 2010 | HP Photosmart 375 InkJet Printer
Change RAM in Acer Aspire 5315
hi
  • Step 2 Protect your computer from static electricity by grounding yourself with an ESD wrist strap or through another grounding method.
  • Step 3 Locate the memory access door for the main memory module. It should be on the back of your computer.
  • Step 4 Unscrew the memory access door and remove it.
  • Step 5 Remove the RAM module by applying gentle outward pressure to the securing clips on either side of the RAM module until they release.
  • Step 6 Rotate the RAM module upward to a 45 degree angle and slide it out of the slot.
  • Step 7 Align the new RAM module with the tab in the connector slot.
  • Step 8 Slide it firmly into place and gently rotate it downward until it clicks into place.
  • Step 9 Replace the memory access door.
  • Step 10 Replace the battery and power up the computer. It should recognize the added memory and reconfigure itself for use
  • Jun 01, 2010 | Acer Aspire 5315 Notebook
    1992 mercury cougar broken glove box latch. How
    you will have to pry it open and then replace the latch.good luck
    Mar 01, 2010 | 1989 Mercury Grand Marquis
    Cartridge
    Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel..........Now Move the Catridge carrier which holds the Catridges manually with ur Hand from right to the Left and from Left to right for about 20 Times............. Now Insert both the catridges inside the Printer............. Turn the Printer On............ If still the same Error Message.... Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... Still if it doesnt work call: 1-800-LEXMARK (539-6275)
    Get the Printer Replaced... Good Luck
    Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Averatec 3700 R1 Notebook - more RAM
    Check out this website:
    http://www.larwe.com/technical/av3715-open.html
    It has complete instructions for the Averatec 3700, with pictures. I used it to upgrade my RAM.
    Aug 07, 2008 | Computers & Internet
    Dell Dimension 4700 PC Desktop Logo
    69 people viewed this question
    Alun Cox
