Loss of ram
I moved my computer to another room and lost 32mb of ram. how can i resolve this issue?
  • biggdogg22 Jan 11, 2008
    no. never added a video card. thank's for trying.
  • 589 Answers
Does the computer have 2 video ports on it - meaning does it have on-board video and someone added a video card?
If so, once you moved it, you may have hooked it back up to the on-board video port instead of the card. Most on-board video used 32mb of memory, which would explain the memory loss.
I hope this helps.
Posted on Jan 11, 2008
How to solve the issue when fautly grounding point casuing ADSL ports failed of ADLE board.
1- Service boards found normal, only the ADSL ports are appearing as Failed and found on almost all ADLE boards of the Huawei MA5616.2- Control Board found normal and there is no communication lost alarm between control board and service board.3- There are chances of some exceptional surge from outside coming through MDF towards system causing Huawei ADSL ports failure. Initially we reset the chipset of board to restore the services and move to step 4.4- We check the grounding point of system and MDF, it was not working and test result is as mentioned in snapshoot. The device was installed in switch room, we check the grounding values of MDF and switch room it was not according to standard and resistance values were too high. We also check the grounding point of other room (Transmission Room) in same building where SDH system was installed, its value was 1.31 ohm which is normal.On investigating we found that the grounding supply of MDF and switch room is different from transmission room and grounding supply of MDF and switch room was actually not working. We connect the grounding cable of MDF and switch room to transmission room's grouding plate and issue resolved after that.
Root Cause
1- Service Board faulty.2- Control Board faulty.3- Exceptional surge from outside lines.4- Grounding / Earthing point faulty.
For such kind of issues specially for Huawei Access Network, must check the grounding of the equipment and MDF. The equipment and MDF should be properly grounded and tested regularly the resistance value of grounding must be in the range around 1 to 5 Ohm.
Mar 22, 2017 | The Computers & Internet
Recover Lost Windows Hard Drive Data
Hard drive data loss is a major problem for all kind of users, if you want to resolve this type of issue, so suggest you get Recover Data Hard Drive Recovery Software that can easily remove or get rid of your all data loss issues as fast as possible.
Do hope it could help you:-
Jul 04, 2013 | Computers & Internet
"Unexpected error (0) occured at line
Hi Ghosh.
Cause of this problem may be:
This behavior can occur because of damaged random access memory (RAM) modules or a damaged RAM slot.
To resolve this issue, use one or more of the following methods, as necessary:
  • Remove one or more of the RAM modules in your computer, leaving at least the minimum amount of RAM required for Windows XP installation. If this resolves the issue, either replace these modules with new RAM modules or reinsert them after Setup is completed.
    NOTE: Verify that your computer's performance is not affected when you reinsert the old RAM modules.
  • Install the RAM modules into different (unused) RAM slots in your computer.
  • If you still experience problems before or after Setup, replace all of your computer's RAM modules with new RAM modules.
Dec 22, 2010 | Microsoft Windows XP Professional
Hi We have just recently bought secondhand-age
RAM RAM RAM...Thats the key here, Your Printer needs more RAM your PC needs more Ram... As much as you can fit in both. You see a Print job must be spooled, the only place it can, fast enough, is in RAM Memory, so if you have BIG files you need heaps of RAM especially in the printer, thats why it can take 32MB RAM, see? To "Print" a MB of data... you may need up to a triple that of scratch space.
Feb 04, 2010 | HP DESIGNJET 500 InkJet Plotter Printer
I have an old packard bell D1000 multimedia intelpentium, 133mh prcessor,1.2gb hard disk,32mb ram.33600bps modem 8x cd rom, what can be upgraded if any. I only use it for grandchildren but would like to...
Most likely, more RAM (memory) will help. That computer can hold a maximum of 128MB or RAM.
The EDO memory for that computer is no longer manufactured.
[72-pin EDO SIMM]
Used memory and possibly non-moving inventory are available.
Any such memory would be at a much HIGHER cost than current memory. (64MB is around $50)
I know you didn't ask for a recommendation; however,
1.) I recommend that you NOT upgrade the memory.
Even if the computer is upgraded to the max, it will still have similar performance issues.
Here is a link to a memory supplier;
or google: ""packard bell" d1000 memory"
2.) Consider a $275 Compaq computer from Office Depot - fully modern computer with DVD / CD, 2GB memory, Windows 7, AMD processor.
I know that's a lot of money for the purpose; however, it may be today's best bargain.
Nov 04, 2009 | Computers & Internet
System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Sep 02, 2009 | R.A.M. Computers Compaq Presario 1075,...
Did not boot and with 3 beep sound
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
I cannot run MS Flight Simulator on my IBM Thinkpad R40, probably because the video memory is 16MB and the program needs 32MB video ram. Some thinkpads came out with 32mb video ram though, and now I'm...
You should be able to buy buying a Video graphics card for your specific computer. You should always check with your manufacturer to make sure that the part is compatible with the rest of the computer. You may even be able to find the part on the manufacturers website. If you do not know much about computers, especially laptops then you should always have a professional assist you that way you dont cause any other problems.
Hope this helps! FIXYA! Please leave a rating!
Apr 28, 2009 | IBM ThinkPad R40 2681
Mobo reads less ram than windows
possible that you have incompatible mem installed, the archictecture of the mem could be 32mb x 64bit could mean that the "BIOS" may only be able to see 32Mb x 8 which to me suggests that this is not the correct mem for this Motherboard, is this mem recovered from another system or an old board. Try and use their memory configurator to find the correct mem for your motherboard (enter the MB manuf and model)
Aug 16, 2007 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
