Question about Dell OptiPlex GX280 PC Desktop
How do i access the ram slots on a Dell Dimension 4700 there are NO buttons on the side to depress I have replace RAM in many computers but I cannot find how to get into this darn box!!!
  • 46 Answers
Removing the Computer Cover Dell Dimension 4700 Series Service Manual
how do i access the ram slots on a Dell Dimension - caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover.
  1. Follow the procedures in "Before You Begin".
  2. Lay your computer on its side with the computer cover facing up.
  3. If your computer cover has a cover latch, slide and hold the cover latch.
  4. Grip the indents on the computer cover, and slide the computer cover toward the back of the computhow do i access the ram slots on a Dell Dimension - cvrop3.jpg
  1. Place the computer cover on a level surface.
Posted on Nov 27, 2009
  • niksization Nov 27, 2009
    Installing Memory
    NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer chassis.
    1. Follow the procedures in "Before You Begin."
    2. Lay the computer on its side so that the system board is on the bottom of the inside of the computer.
    3. Press out the securing clip at each end of the memory module connector
    4. Align the notch on the bottom of the module with the crossbar in the connector.
      1. Insert the module into the connector until the module snaps into position.
    5. If you insert the module correctly, the securing clips snap into the cutouts at each end of the module
    6. Close the computer cover
    Brigadier General:
  • 10,406 Answers
From the manufacturer's web-site:
http://support.dell.com/support/edocs/systems/dim4700/
select the "language" that you can read (English?)
Then, select "Service Manual".
Then, select "View" or "Download".
Then, read the "Removing the Computer Cover" section,
or just look at the pretty diagrams that show you how.
Posted on Nov 19, 2009
    Sergeant:
    Champion:
  • 273 Answers
They aren't that difficult onced you've done one. Open the pins and pull the one out. With both side flaps open slide the ram in its a little tricky but make sure its snug. When you get the module in snug you will be able to snap the pins closed. They wont close until you have the module in correctly though.
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
This is a service manual for the unit, how to get to cover off ect
http://supportapj.dell.com/support/edocs/systems/dim4700/sm/index.htm
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
I can't close tower cover
When your computer appears to slow down, one way to help increase its speed is by adding memory. You can easily purchase memory chips from various online sources or if you have a Dell Dimension and want to stick with Dell products, you can purchase additional memory chips from Dell itself. It is not difficult for a non computer person to add memory to a Dell Dimension, although sometimes, it is cheaper to purchase a new computer and then install additional memory.
Shut down your computer, turn the computer off and unplug it. Open your computer case. There will be two thumbscrews on the back of the Dell Dimension computer case that will release the cover. The side of the computer case will then slide backward and lift away from the rest of the box. Locate the slots for RAM. These are short off-white slots that are near the power supply on the motherboard. They will be slightly longer than the RAM you are about to add. There will be at least one RAM chip already in place in one of the slots. Place your new RAM chip into a blank slot gently. It does not matter which slot you use; any will work. When you press the RAM into place, be sure the notch on the chip lines up with the slot. There will be a guide on the slot to ensure that you do not insert the chip backwards. Press down on the RAM chip until it locks into place. There are two guides on the side of the slot that will snap into place on the sides of the chip to ensure the chip does not fall out. It will take a bit of pressure to make the chip snap into place, so press straight down into the motherboard to get the chip in place. Close the computer case, put the thumbscrews back where they belong and start up the computer. Your Dell Dimension will sense the new RAM, which will be available to the operating system when the computer starts up. Hope this helps.
Dec 30, 2012 | Dell Dimension 4600 PC Desktop
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
My dell 4700 diagnostic lights A&B are yellow, C&D are green & the monitor is dark. I can not get anything to show up on the monitor. Everything has power & was working normally yesterday....
the LED indication is a Memory failure. Make sure when inserting RAM that the power is unplugged and you press and hold the power button till all power is discharged from the motherboard. WHen inserting RAM, make sure levers are int he full back position and you press down firmly with both thumbs till the module snaps in place and the levers snap up in the locked position on their own (DO not pull up the levers)
If there is no change trying RAM modules in slots individually, then either all RAM modules are damaged, or the slot is bad, in which case a motherboard is required
Oct 23, 2010 | Dell Dimension 4700 PC Desktop
Dell computer won't boot
I have the same problem with the same computer. If you get alarming beeping sounds and the fans whir, but there is no video- then the problem is most likely with the RAM. Try re-inserting the RAM sticks. Otherwise- if there are no beeping sounds and no video but the fans work or if the computer seems to be booting up but there is no video then the problem is probably with the video card. Try reconnecting the video cable and re-seating the video card. RAM slots and card slots are not very good.
Otherwise- if you get no power at all and just a blinking amber light on the front of the computer-then you have the same problem as me.I don't know.
Aug 03, 2010 | Dell Dimension 4700 PC Desktop
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Cannot access the box to replace RAM. Cannot find
Hello
Thank you for using
Service manual link
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Dell Dimension 4700 PC Desktop
Beeps, wont boot up
Most of the time when it beeps, and there is nothing show on the computer screen, it is a RAM problem. A stick of ram may have gone bad. If you have two sticks of ram in the computer, you can try to remove one stick at a time to see which one might have gone bad.
Mar 23, 2009 | Dell Dimension 4700 PC Desktop
Dell dimension 4700 computer keeps shutting down at start up
That's pointing to the memory. Try re-seating the RAM.
Mar 19, 2009 | Dell Dimension 4700 PC Desktop
Dell 4700 network card install
You can find all needed information on the Dell website.
Look here.
How to open your computer is explained here.
Please post some feedback
Apr 22, 2008 | Dell Dimension 4700 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
