American Standard Freedom 80 - 9 blinks - Ignition issue
Just purchased a house. It has an American Standard Freedom 80 furnace. We've been in the house just over two weeks. Initially the furnace was working. We had a breif warm spell and when it started getting colder here, I noticed it blowing out cold air even though the heat was cranked to 90. My Wife said if she turned up the temp high it would eventually get warm. Not sure if it was because it was getting warmer outside, or if it was because she was turning the heat up. I checked and the error light on the furnace is blinking 9 times. The inside panel indicates ''Check Ignitor'' more information on line says ''Check Ignitor Circuit and Line ''N'' to 24VAC ''Common'' voltage (≤ 2 volts)[possible grounding problem]''. I found some information on the furnace the previous owner left us the ignitor was replaced on 11/10/08, a year ago. I ordered a replacement ignitor and installed it today, still having the same issue. Tried cleaning off the flame sensor just in case, but from what I read that is probably not the issue.
It is still not lighting and getting 9 blinks. It just runs and blows cold air if left on. The draft inducer motor starts then stops, the normal blower kicks in but the ignitor doesn't get hot. Not sure how this would be related but the cable guy was here setting some stuff up between when I know it was working and when I found out it wasn't...just not sure what it means to check the ground, if possibly a cable ground could have messed this up. Also, worried the vents may have been blocked at some point by boxes from moving.
  • 1 more comment
  • Dave Graham Nov 19, 2009
    Thanks so much for the quick reply. I will check out the airswitch...once I find out what it is. I'm a computer technician, I've had to learn alot about furnaces in the last few days.
    I talked with my 10 year old, she was in the House when the cable guy was running cable. She pointed me to a newly placed cable splitter next to the fuse box. There is a green wire running from the cable splitter to two wires (think they would be the wires). They are two thick metal wires, the green wire from the cable splitter is connected to them. I think the cable person may have connected the two wires together in order to connect the cable ground wire.
    I disconnected the green wire from the cable splitter and tried to restart the furnace, still getting the error light blinking 9 times. So, I reconnected the wire...when I did there was a very tiny bright light. Should something like that spark? My guess is no.
    I don't have the tools to remove the connector he put on the two wires at the fuse box. I would like to seperate them to see but not sure if it's worth the effort. Could something like that cause a grounding issue at the furnace?
    The cable tech was here on Friday. It was a warm weekend, I noticed the Furnace was pushing cold air on Sunday afternoon when it started to cool down. I think it's way to much of a coincidence...
  • Dave Graham Nov 20, 2009
    Check resistance on HSI and it measured 15 (new to using mutlimeter so hopefully I'm using it right). Checked the old one and got the same measurement. Disconnected the connections on the pressure switch and the multimeter stayed at 1. Not sure if I was doing it right though...cable company is coming out to make sure they didn't mess something out.
    Tested Pressure swtich off the furnace and was able to get it to make contact. Ohm reader read 0. Tested again on the furnace and it's not making the contact.
  • 614 Answers
I will try to help. Your furnace has to have a good ground before the igniter will work. The draft fan starts purges for a few seconds and the ignitor is supposed to come on. If not check to see if the contacts on the air switch on draft motor are closing. If you ahve changed the ignitor that is not your problem. Another possible problem is the baord that feeds the ignitor. But check the air switch first Rus. Keep in touch.
Posted on Nov 19, 2009
  • mgbloom Nov 28, 2010
    I have same problem. Electrician and plumber spent hours checking connections and replacing parts, but still will not ignite. Induction blower goes on for 2 seconds then main blower, but no ignition. It worked for a few weeks after cable installation, then this problem started. Any sugestions? Thanks, Cold In Boston.
American Standard Freedom 80 single stage fires up... runs and blows heat for a few minutes then shuts off but then 5 minutes later it repeats the cycle. Any ideas? I have replaced the filter.
A 5 min run time tells me that it is overheating. Probably a dirty evaporator coil, or a loss of airflow due to blower issues. Or even a high temp safety that is opening prematurely? Tstat is calling for heat so its doing its job. It could be overheating or a fault at any of the components in the furnace. 90 percent of the time its a dirty blower wheel, EV. coil, or a missing filter that's so dirty its cutting off the airflow. Hope this helps!
Mar 01, 2017 | American Standard Heating & Cooling
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
I have a American Standard furnace Freedom 80 Mod# AUD080C936H3 and am looking for a manal or can you tell me how the exauhst is done. Can I use PVC
Hello, The only time pvc is allowed is if the Furnace is 90% or greater in effiecency, the combustion gases are cooler due to the fact that two heat exvhangers are used. One pipe will be you air intake and the other the exhaust and they can be routed through the roof or sidewall. If the Furnace is 80% then you must use double wall vent pipe and have it connected to either a liner in a chimney or routed through a roof but pvc can not be used.
Aug 28, 2011 | American Standard Heating & Cooling
I changed the furnace filter on my american Standard Freedom 80 filter and now my burner won't light.
does anything happen, i door that you removed might have a kill switch on it so if the door comes off or is not installed right the furnace wont light, let me know and maybe i can help. wally
Mar 10, 2011 | American Standard Heating & Cooling
How doI replace the motherboard on a American Standard Freedom 80?
Hello, to replace the intergrated control board on your furnace you need to turn off main power to your furnace, then label the wires so you will know where they go on the new board. Then just take the old board to a hvac supply store and they will give you a replacement and just connect the wires to it and turn on Furnace.
Mar 02, 2011 | Heating & Cooling
I have an American Standard Freedom 80 furnace. When I turn it on it runs and runs and then shuts down and then the cycle starts again. It runs but never ignites. I was wondering if there is anything I...
EIther the valve is faulty or the ingiter is corroded or faulty. The inside of the ingniter has a shaft with a probe that keeps heated so it can ignite. It can be corroded.
Oct 27, 2009 | Heating & Cooling
Heating & Cooling Logo
3,212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
