Question about Samsung PLH403W 40" Rear Projection Television
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
One day my Samsung Tantus (Model SP-43J8PF) rear projection tv had this green hue to it. Most of the other colours are there but everything is greenish. It is really bad for night (dark) scenes as you cant make out the subtle differences in shading etc and just looks green. I think it has also (might have) got slightly worse over the last 3 weeks although I'm not certain.
All the bulbs are working, its like the green is overpowering the other colours almost.
I'm ok at basic electronics but Im pretty lost when it comes to a tv. Any suggestions on where to start or what might be wrong is appreciated.
And is it worth fixing too?
  • 2 more comments
  • fixta128 Nov 19, 2009
    Thanks for that but I cant get into the service menu. I have tried both with the TV off and on, But it fails to bring it up. Are there any other service codes?
    I have tried accessing the service menu but it doesnt work.
    I have tried with the TV on and OFF but no good. Its seems as I hit the 1 key the TV starts turning on, which seems to be ruining the sequence.
    OK - The Correct Service Menu Code with the TV off is: DISPLAY - MENU - MUTE - POWER. Now i made some good adjustments under the G2-Adjust menu, but is doesn't appear to be saving them. I tried hitting Mute x2 then Power but It must be something else. Although somehow the picture is looking better (but the G2-Adjust) Picture is really good and colourful and bright etc but then going out of the G2-Adjust option takes it back to the 'normal' picture.
    Many Thanks I am slowly getting there!
  • 566 Answers
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Posted on Nov 19, 2009
Testimonial: "Very helpful and fast! Thanks so much!"
  • Jacques Marin
    Jacques Marin Nov 19, 2009
    There might be other sequences for older model but i`ll have to look it up.
    I`ll keep you posted soon
  • Jacques Marin
    Try thi one and let me know.
    It doesn`t say much but it might give you a few more buttons to play with.
    - The buttons are active in the service mode.
    1. Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left
    Arrow Right, Menu, Enter, Number Key(0~9)
    2. Function - Control Key : Power, CH +, CH -, VOL +, VOL -, Menu, TV/VIDEO(Enter)
Green hue
Hi,If you are experiment hues,color distortion ,black and white picture,hear buzzing high pitch sounds, it could be time to replace the color wheel.Your part # will be BP96-00250A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm? and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one!
Feb 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Samsung Tantus problem
your main power supply is gone out
Aug 30, 2008 | Samsung PCH521R 52" Rear Projection...
Only have a green colour for all tv and dvd pictures on Samsung Tantus Rear Projector TV (Model # SP-43J8PF). Is this the globes or is it stuffed?
ok hi there now inside a rear projection tv is 3 globes i big mirrior
and all the wires are under now it sounds like you do need to replace the globes but to be sure the others are ruined you can pull it apart take the screen off
so now u can see inside u will see three bulbs full of liquid
make sure none is leaking as they can
then turn on your tv (its all safe) put on a channel and look at the bulbs to see if one or any aint workin
if there are working turn tv off and get a lint free cloth or tissue and wipe the top of the bulbs do not turn them adjust them at all
need any more help im chris07551
Jul 18, 2008 | Televison & Video
Green bow tie, convergence not helping
Yes, your geometry correction has failed and you will need to seek qualified tech for help. You need what are called STKs and you should be able to get the job done inhome for under 300.00
Craig www.classtorations.com
Jun 08, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung big screen tv model pcl542r has a green or red tint to picture
do you have a service manual for this tv because it may be your red drive circuit and you need to trouble shoot it if you don't have a service manual for your tv I will post a link where you can get one plus free online tech support to help you troubleshoot this problem
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung tantus 1080i
hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Feb 17, 2008 | Hitachi 57F500 57" Rear Projection...
Samsung PLH403W 40" Rear Projection Television Logo
1,118 people viewed this question
Jerry Greenberg
Jerry Greenberg
