Question about Motorola Mobility RAZR V3
Motorola razrv3 phone is fully charged turns on then after a little while it goes blank, have to remove battery replace it back then turn it on then the same thing! aggggghhhggghh going crazy with the thing, help please?????
    Brigadier General:
  • 7,752 Answers
You need to get the firmware reflash on the's best to take it to a mobile store or mobile repair and have it done there...
Posted on Jan 11, 2008
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
My phone died on me as I was sleeping and this morning I had charged it a little bit before I left and than Started charging it in the truck, My phone than got EXTREMELY hot, and turned off now it wont...
From what you described, it sounds like you need to replace your phone's battery.
Sometimes, when a battery goes bad, it will overheat. Then, it will not work at all.
This sometimes happens when generic car chargers are used instead of - in your case - an actual Motorola charger.
You should remove the battery from the phone. Do not try to charge this same battery and do not use it in your phone again.
Purchase a new battery and charge it for 12 hours before turning your phone on.
Many times, when you remove a defective battery that has gotten hot, you will notice that it looks 'puffed' slightly. But, this is not always the case. Even if not 'puffed' outward a bit, your battery can still be defective.
Mar 29, 2010 | Motorola Mobility CLIQ Cell Phone
Motorola razor not powering on
is this the first time you are trying to use the phone? if so, (i have this phone so if you have any more problems just ask), hold down the red phone button (the button to put the phone down) for as long as it takes to turnn it on (usually about 10 seconds).
if this isn't the first time you are using it and it has worked before, charge it fully, then take the battery out for 30 seconds and put it back in. if none of this works, take it back to the shop and ask for a replacement.
May 29, 2009 | Motorola Mobility RAZR V3
Screen goes blank before i can key in pin number
have the flexcable replaced and try also a new battery
Dec 27, 2008 | Motorola Mobility RAZR V3
Blank or White screen on new Motorola Krzr k1 cell phone
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
W380 goes blank when connecting via usb in files transfer mode
Finally I got it to work. I had to fully charge my battery as I had noticed that when i was trying before the computer was trying to charge the battery. Once I had fully charged the battery and then attatched it to the computer put it into file transfer mode it was really easy. Anyway I hope you have managed to solve your problem.
Nov 20, 2008 | Sony Ericsson W380i Cellular Phone
Motorola Z3 Rizr won't turn on
when you plug in the charger cable to your phone, make sure that you allow it to charge at least 2 hours, if your phone shuts off immediately after this amount of time, you likely need a new battery, they will wear out after a certain number of recharge cycles.. contact your motorola distributer or motorola website to purchase a replacement. Note do not accept "Non-Motorola Batteries or chargers as these are not guaranteed to provide the proper current necessary to safely recharge your battery, if you notice the battery getting Hot, then disconnect the charger immediately and let it cool, before removing and disposing. Remember it is normal for the battery to be warm to touch while charging or the phone itself is in use. but if it gets hot to the touch this is not normal, and the battery needs replaced..
Nov 06, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola razrv3
1. Turn the phone off.
2. Close the phone and turn it around so you can look at the back.
3. Use your fingernail in the middle at the top of the back and pull back toward you.
4. The battery is the black rectangle.
Oct 09, 2008 | Motorola Mobility RAZR V3
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
