Question about HP DeskJet 940c InkJet Printer
Wont print it has ink in it what do i do - HP DeskJet 940c InkJet Printer
    Problem Solver:
  • 5 Answers
Yr printer is not properly install or setting might accidentally changed.
Pls reinstall yr printer.
If problem persist,
Just right clip "my computer", choose "properties", then choose "hardware". Check the port or USB where yr printer connects & update the driver.
Good luck.
Posted on Nov 19, 2009
- I have just changed the black ink and now it wont print so I have changed the black ink again and it still wont print anything black - any ideas
The black ink nozzle in the print head might be blocked. Print a test page with a huge black image. Like: just start word, create a square through "illustrations" and fill it completely with black. Print it once or twice and see if finally the black ink may come out.
Through printer properties (windows control panel) there might be additional cleaning options.
Feb 24, 2015 | Office Equipment & Supplies
Can the printer still print on low ink on colors? It wont let me print anything, even black and white. On windows 7.. any problems there? It says that the printer is printing the page. But the Cyan is low...
It will print with no ink it will just be patchy.
It is also best to not let them run out of ink as they dry up in the print nozzle a pain to get working again and uses a lot of ink as you need to do several head cleans.
You may need to turn it of at the power point then after 3 minutes turn it back on again.
Also reboot your computer it may have not have started properly.
This should reset it.
Feb 07, 2018 | Epson Stylus Photo R200 InkJet Printer
Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Refilled my black ink but my color ink is empty so it wont print
Apparently I just had the same problem and I managed to fix it! Click on the OK button on the printer to ignore the low ink level error, then you'll be able to print and scan.
Jun 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
New black ink wont print
goto printing preferences in printer and faxes. open properties oof printer. change print quality to best or maximum.
Apr 24, 2009 | Office Equipment & Supplies
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer Ink wont work!
HI~ First Check your ink..if you using compitetor ink or CISS ink , Remove The Rubber that are in the Ink Cattridge there, Coz When the print head **** the ink from catrige with pressure it will stuck the print head from spraying the ink out...  After Remove those rubber that are on the ink catrige you need to clean it to release those presure that build coz of those ink catrige build....                                                   If it dont work your print head need to be purge and you need to get in Maintenance mode...then coz you are using generic ink it maybe have spray to other part of the printer the ink Sensor is very close to ink absorber and the Generic ink usualy leak coz the design are not good but it is cheap and you need to know how to use it...
Dec 18, 2008 | Brother Multi-Function Center MFC-240C...
My Canon printer wont print.
You could be facin one or both of these problem, Either the ink which u say is a refill is not good, note that they do expire, ur ink containers may be damaged or the ink sensors
Feb 22, 2008 | Office Equipment & Supplies
HP DeskJet 940c InkJet Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
