Question about Gateway GTW-P42M102 Television
I have a Gateway 42M203 plasma. I need info for voltage outputs and trouble shooting. With no input selected, get nice blue screen with hourglass "no signal" screen-saver image. Go to an input (TV,AV1,Comp.) screen goes to a light magenta with dark megenta (bar code type) stripes verticley.
  • boilerataz Nov 19, 2009
    I already have the manual you directed me to. I replaced the AVw/tuner module, and the image board. The repairman I talked to seemed to want to know the voltage outputs to see where the problem component might be. Have you incountered the problem I have discribed?
    Yes, the Service Manual will be helpful.
  • Gateway Master
  • 19,396 Answers
Hi.
Click the link below to download the complete service manual:
http://support.gateway.com/s/Manuals/HomeTheater/GTW-P42M203.pdf
Please do not forget to leave feedback.
Thanks.
Posted on Nov 19, 2009
When i hit breaks or turn lights it kills the power to motor
Look for a bad engine ground ! Voltage drop the ground circuits for charging system , body grounds etc... Go on you tube an check out videos on basic automotive electrical trouble shooting , voltage drop testing , how to read a wiring diagram , how to use a DVOM -digital volt ohm meter . Go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Also check out how to test PCM/ECM inputs an outputs ECM Inputs and Outputs Diagnosis
Apr 24, 2016 | Cars & Trucks
Pioneer plasma TV. When I power on the red power turns blue, as it should. But then I hear a second "click" and the actual tv never powers up. The blue light will then blink thirteen times over and
if you know electronic repair, what you can do is trouble shooting. you will need to check weather the output voltages from the power supply going to the sustain board doesn't drop or need adjustment.
Oct 28, 2012 | Televison & Video
I have a Samsung 50" plasma HDTV, about 6 years
either backlight (flourescent bulb inside) or power supply for backlight went bad - if you have voltage meter you can check if there is voltage where bulb goes and if there is replace bulb or if no power you will need to trouble shoot power supply which is common thing to go bad on these sets.
it is usually not worth paying to get this fixed if it is power supply and you might be better off just getting new set - sorry i know that is not what you were hoping to hear but....
good luck!!
Mar 27, 2011 | Samsung Televison & Video
I've connected my new Sony Blue-Ray Disk Player to my RCA F25645 TV via the three (Red, White, Yellow) composite cables but the screen only says "unusable signal" and will not display the Blue...
The output from the blu-ray is probably component video, where the brightness, blue and red difference signals are the three outputs. Sounds like the TV only has composite video input so won't work. Check the manuals, if you can get a composite signal from the blu-ray then your TV will display it but not high definition. A HD LCD or plasma TV is needed to show the blu-ray films in high definition.
Jan 02, 2011 | RCA F25645 25" TV
Hello
There is no RGB connector input at the rear of your RCA tv. There is Video, Audio-L, Audio-R and S-video inputs. You won't get any response from your TV, if you connect the RGB connector to the above said audio video connections. You can connect the Blu-ray player with S-Video connector. After connecting it with specific S-Video cable to your TVs S-Video input and Blu-ray players' S-video output, assaign the input of your TV to S-Video, by going to its Menu, and sufing through it. OK.
Screen changes between color as a demo function.no signal
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Sep 24, 2008 | Gateway LCD26TV 26 in. Television
Plasma
The voltages are on the Printed circuit boards and the schemo's are online. What is wrong with set again?
Jan 31, 2008 | Televison & Video
Plasma screen
supply problem. check the power supply of the controlling unit. not stable.
Jan 14, 2008 | Gateway FPD2275W LCD Monitor
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
Open Questions:
Televison & Video Logo
80 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
