Question about Samsung HLT-5075S Television
My samsung 50" dlp tv's lamp keeps burning out. owned it for 2 1/2 yrs now. 2nd bulb has just went out. any ideas why?
    President:
  • 1,284 Answers
The only thing that will cause the lamp to fail that fast is the ballast. The ballast is part number BP47-0037A and I am including a link so you can purchase the ballast. Please take a few moments to rate my answer. Thank you..
http://www.partstore.com/Part/Samsung/Samsung/BP4700037A/New.aspx
Posted on Nov 19, 2009
  • Samsung Master
  • 8,457 Answers
Buy the original Samsung products,not clone will help.
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
Samsung 50 inch DLP has power will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.Note lamp sometimes doesnt look bad when it's bad.The lamp you need is BP9601472A you can find it here http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm?Click=48173.Have a blessed one!
Apr 29, 2010 | Samsung Televison & Video
I have a samsung 56" pedestal DLP HLP5685, and it keeps turning off and on, on it's own. The bulb is only a few months old. Any suggestions?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600677A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00677A-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00677a-lamp-oem.htm?Click=48173.Have a blessed one!
Apr 26, 2010 | Samsung HLP5685W 56" Rear Projection...
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Well...it will be about 5 years now with this tv....2nd bulb....was 2,000......ends up costing 2250....and counting...id buy another tv ....but to buy a bulb is simply cheaper....short end
I can't believe a lamp would cost that much. I service LCD and DLP projectors and the cost of lamp range between 250 to 500 max. Lamps will lose alot of life if they are turned on and off alot. The mfg's rate the life of a lamp if it is turned on and remain on till they burn out. THe lamp is given a high voltage when they start. This cuts the life down. Try searching for lamps to see if you can find a cheaper price online.
Feb 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My samsung 50 dlp tv has stopped working it will come on for 2 minutes i will get a picture and then i lose the picture i still get the sound but the tv goes black what is the problem there are three...
on dlp units there's a bulb that needs to be changed
avery 2-4 yrs..try and do that first..if that wont solve the problem..then try the color wheel if u here a humming noise before it shuts down.
any questions--->bhzrdg@yahoo.com
Jan 24, 2010 | Samsung Remote Control
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
Apr 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Samsung HLT-5075S Television Logo
483 people viewed this question
Jerry Greenberg
Jerry Greenberg
