Question about RIM BlackBerry ® 8830 Cellular Phone
I accidently put the microSD card into the Sim Card slot. Now it will not come out. is there a way to remove the upper half of the back to get it out.
When you remove the battery door, battery, any cards that you can still get at. There are 4 screws that you can see. If you remove these, (T5 or T6) the front should lift out and you should be able to better get at the SIM slot. The SSD may be fried, and the SIM slot may be damaged. Take Care
Posted on Nov 29, 2009
How do you know what slot to put sim card in slot 1 or slot 2
You either have a dual SIM card phone (it can use two SIMs with two different phone numbers) or you're confusing the MicroSD memory card slot with the SIM card slot.
If you truly have a dual SIM card phone, just put the SIM card in slot 1. Your phone's user manual should be able to offer further info.
May 19, 2017 | Cell Phones
Installing additional memory into my Jitterbug smartphone--How do I do it?
Per the Jitterbug Smartphone manual, on page 124:
https://www.greatcall.com/docs/default-source/pdfs/jitterbug-smart-user-guide.pdf
Adding more Memory Your Jitterbug features a microSD expansion slot to add up to an additional 32 GB of memory. The following is how to add more memory:
1. Remove the Back Cover using the Back Cover Release notch found on the bottom corner.
2. Locate the microSD expansion slot, which is below the External Speaker, and carefully insert the microSD card into the expansion slot until it clicks into place.
3. Replace the Back Cover.
IMPORTANT! Do not remove the SIM Card located opposite of the microSD expansion slot. Tampering of the SIM Card may cause issues with connectivity to the GreatCall network.
Sony xperia miro manual
Here's a link to the official user manual for Xperia Miro (http://blog.clove.co.uk/wp-content/uploads/2012/09/Sony_Xperia_Miro_Userguide_EN_ST23.pdf). On page 8 they described how to insert a microSD card into Xperia Miro.
Aug 21, 2014 | Sony Xperia miro ST23i Smartphone -...
Show your memory card location
Remove the back cover by holding the phone firmly then slide in the back cover of the handset. You will now see your MicroSD and SIM card slots. Take your SIM card and slide it into the slot provided with the chip facing down. You will also see a small diagram showing you which way to insert the SIM card. Now slide open your MicroSD memory card slot gate, pop your MicroSD memory card into the slot, then close the MicroSD memory card slot gate by sliding it forward then backwards.
Oct 29, 2011 | LG GD510 Cell Phone
I have lenovo G-560 laptop,in laptops user guide i saw sim card slot in my laptop for using internet.but my sim card is so much small for this slot ,how can i use SIM card
Is it a SIM card or a SD card (sim is for phones from providers ect. AT&T), (SD card is for storage)
If it is a SD card then it might be a microSD if so then you are going to have to get an adapter from microSD to SD. You can get them cheap off ebay.com
Aug 06, 2011 | Computers & Internet
How do I insert a memory card into my Nokia 5310d? Thank you
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia uses approved industry standards for memory cards, but some brands may not be fully compatible with this device. Incompatible cards may damage the card and the device and corrupt data stored on the card.
1. Remove the back cover of the phone.
2. Insert the card into the microSD card slot with the contact surface facing down, and press it until it locks into place.
Jun 12, 2011 | Cell Phones
How to take the sim card out of the nokia 5230
Hi
On the left edge you'll find two covered slots, one for the microSD and one for the SIM card.
While you can easily insert a SIM card into the slot from the outside of the phone, you have to remove the back cover and battery to take it out, which makes this design a bit odd.
The rear cover is pried off with a fingernail to get to the battery compartment, and it goes back on with a simple snap.
Regards.
Aug 30, 2010 | Cell Phones
How do i put a micro sd in to my samsung intensity
There is a slot on the side of the phone where you can insert a MicroSD card. Remove the back cover (there is a slot at the top, near the camera, where you can pry the cover off with your finger) and as you're looking at the battery, the MicroSD slot is to your left, just above the camera button. Just slide the memory card in there.
You should turn the phone off before inserting a MicroSD card. Without the back cover on, the battery won't make a tight connection, and if it jiggles at all it will lose power and shut off anyway.
Jun 08, 2010 | PNY 2GB microSD Memory Card
Where do i find the micro sd on the nokia 6300
1. Remove the back cover of the device.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
RIM BlackBerry ® 8830 Cellular Phone Logo
55 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
