Question about Frigidaire Dishwashers
I have a fridgedaire model FDP635RFR3 portable dishwasher and i cannot get it to fill with water, my sink backs up and sprays out... any suggestions??
  • 464 Answers
You probably need to replace the water inlet valve if you don't get water into the dishwasher. The part you need is number 3 in the attached breakdown. The part number is: 154219601. Hope this helps.
Posted on Nov 19, 2009
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Frigidaire FDP635RFR3 wont drain.
    Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
    Apr 28, 2010 | Dishwashers
    Dishwasher top spray bar does not spray due to low water fill
    Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
    Mar 28, 2009 | Dishwashers
    Water in the dishwasher after the the cycle is complete
    Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
    Kenmore 18inch Portable Dishwasher
    how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
    Dec 31, 2007 | Dishwashers
    Dishwashers Logo
    158 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
