Question about Microsoft Office Standard for PC
I want to remove My freeze and PC Mighty Max from my computer. Both of these pop up when I am online. Can you help me with removal?
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Select My Freeze
Click Remove
Select PC Mighty Max
Click Remove
Restart your computer.
Posted on Nov 19, 2009
How to replace freeze plug
use a punch or a freeze plug remover and knock it out of the cylinder head or block. make sure you drain the cooling system first otherwise there will be a massive mess. clean off seated surface of cylinder head or block with crocus cloth, apply a thin layer of grease on either freeze plug or on the seating surface and use the freeze plug installer to knock the freeze plug back into place.
Aug 28, 2014 | Cars & Trucks
How to remove water pump from a 95 Mighty Max
Assuming it has a 3.0 liter V6 engine, you'll need to remove the front of the engine off including the timing belt. If you are to replace the pump, replace the timing belt with tensioner too.
I hope this may have assisted,
Tom
Feb 14, 2011 | 1995 Mitsubishi Mighty Max
Cant locate fuel pump
the fuel pump is located inside the fuel tank, the fuel tank must be removed to change the electric fuel pump.
Apr 26, 2010 | 1995 Mitsubishi Mighty Max
How do I remove the mighty pc add that keeps
go to add or remove there select that uninstall it
Mar 09, 2010 | Microsoft Windows XP Home Edition
Lever on defrost on 1991 mighty max pick-up
To access these controls/cables you'll need to partially remove the center dash components and come from underneath the dash to repair.
I hope this may have helped,
Tom
Oct 13, 2009 | Mitsubishi Pickup Cars & Trucks
Anti freeze dripping from exhaust
this is caused by a blown cylinder head gasket.
Apr 18, 2009 | 1993 Mitsubishi Mighty Max
Tried to remove PC Mighty Max and cannot!
Is it now missing from add/remove programs.Windows add/remove
is a useless program anyway, you can go into safe mode(reboot your pc tap f8) and delete the folder that is in your program files. Return to normal operation. There are two ways to remove the registry keys
for this program,manual and a free cleaner,called Ccleaner, you should get this and clean your registry,besides it is good to clean
it when you install and uninstall programs. Below is the link to the free cleaner,its not bad for free.
http://www.ccleaner.com/download
Apr 01, 2009 | Microsoft Windows XP Home Edition
Computer in 1991 mits pick up
I recently replaced the ECU in my 91 mighty max. If you remove the glove box you will see it on the right hand side.
Feb 28, 2009 | 1991 Mitsubishi Mighty Max
1991 mighty max
If it is 4X4 and you re not going far. Put the transfer case in neutral. If it is 2X4 standard transmission, put it in neutral. If it is an automatic transmission you need to remove the driveline.
Jul 10, 2008 | 1991 Mitsubishi Mighty Max
Microsoft Office Standard for PC Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
