Question about Exercise & Fitness
Fuel FT94 Treadmill. LS error
Fuel FT94. 2 years old. 408 miles. Use: walking. Problem: LS error when 3.5MPH is exceeded. Troubleshoot through Fuel service by phone. Replaced motor, speed sensor, and opto-chip on control board. Relocated speed sensor to 1/16th inch of flywheel. Negative results on all corrective action. I think I need to replace the control board, but $200 is too steep. Any advice? Thanks in advance.
  • 14 Answers
SOURCE: replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Posted on Jul 08, 2009
  • 16 Answers
SOURCE: What silicone oil is needed on Horizon Paragon 408 treadmill?
You should be able to google the answer.
Posted on Jan 29, 2010
  • 103 Answers
SOURCE: Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Posted on Feb 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: We have an L7 or L8 treadmill. About 2 years old.
Unplug unit remove motor shroud then plug in unit hit start it and listen to where the sound is originating could be the drive belt or if you are walking on it then it could be the running deck post needs to be lubricated
Posted on Apr 17, 2010
maxtreadmill
  • 832 Answers
SOURCE: Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
Posted on May 06, 2010
2005 68K miles. No service history and trader has no indication that works have been conducted. Should I walk away or asks for key checks and report to be provided? any steer welcome
It's a 11 year old car, that's had about 6200 miles per year put on it. 12,000 is considered a normal yearly average. Unless you can have it looked over by a trusted mechanic, I would be leery about trusting only reports. Many things deteriorate from age alone, not just mileage. I would walk away, unless a knowledgeable third party checks it out.
Jul 28, 2016 | Cars & Trucks
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
http://electro-medical.blogspot.com/
Mar 08, 2016 | Exercise & Fitness
E-bay phone number
Ebay Phone Numbers: (408) 558-7400
(408) 558-7401
1-800-322-9266
1-888-749-3229
1-408-376-6554 FAX
Spokesperson: Kevin Pursglove, 408-558-7458
Hours: 7:30AM - 5:30PM PT M-F
Employee's Extension: press 1
Dial by name directory: press 0
Customer Service: press 2
Operator: press 3
Oct 31, 2014 | Computers & Internet
I have toyota tundra v6 hesation on depression of
After about 6 to 7 years all the ignition coils fail
Keep diagnosing the cylinder misfire issues
Need professional scan tool software, to use Mode $06,
& look at other data, as your not going to get a perfect
fault code every time & just replace a failed part
There are times when professional tools won't work & you
have to walk a new coil or use a scope on a road test & that
could take months before the coil goes down
How about the spark plugs ?
Over 3 years old ? loose them
Smoke the intake-- for vacuum leaks
Look at fuel trim for that bank with the Misfires
O2 Sensors over 100,000 miles
Fuel Pressure Correct at fuel rail?
Sep 26, 2014 | Cars & Trucks
My car is driving slow what can that be
Your vehicle is 14 years old, and probably has quite a few miles on it. START WITH A MAJOR TUNE-UP, INCLUDING PLUGS, WIRES, COIL PACKS, and a FUEL SYSTEM INSPECTION.
You'll probably find that the fuel filter is old and should have been replaced years ago :)
Jul 20, 2014 | 2000 Lincoln LS
Spirit treadmill st200
That machine is way too old to put any money into it. The fix for that particular problem is to replace the deck and belt.
Oct 21, 2017 | Exercise & Fitness
After walking for about 2 miles the treadmill turns off
please the video and proceed according and fix it. God bless you
Mar 22, 2013 | Exercise & Fitness
I love walking and last year bought some great walking shoes. They still seem in a good condition. When do I need to replace them?
Ideally, walking shoes should be replaced every 300 to 500 miles which for an average committed walker would be between 3 and 6 months. Don't judge it by how the shoe looks as the inner support could be worn away but the shoe still look great. You will feel the difference between an old and a new shoe.
Feb 20, 2013 | Luggage & Travel
Po302 code also po316 code
Put the old coil back in #2 & walk the new one to another cylinder
PO Codes are wrong, as many times as correct on a ford
Forget the 316
Your best to look at fuel trim with a professional scan tool
& cylinder misfire counts in Mode #06 also
Those trucks have leaking injectors some times, but that isn't
the code your getting
Spark plugs can't be in there over 3 years
The front 2 oxygen sensors have to be replaced at 100,000 miles
Do those 2 items & then diagnose the misfire or walk the coils
Feb 12, 2013 | 2003 Ford Expedition
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
Exercise & Fitness Logo
908 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
