Question about Samsung SGH-t629 Cellular Phone
When i insert the charger that was partually broken inside the socket it powered on and then went out what could went wrong
No power to Miele W404 Plus washing machine.
hi
it could be faulty flex cable from the washer to wall socket or where the flex cable is screwed into the terminal block inside the machine come out or broken
Dec 21, 2017 | Miele Washing Machines
SM-T211Why will tablet not turn on or charge
When it does not have enough power, it can't switch on. And even a new charger can't get in any power if inside the tablet is something wrong. Like a dirty or defect connector, or inside a bad or broken cable. also check the connector, where you put the charger cable in.
Feb 13, 2015 | Samsung Galaxy Tab Tablet PC
No power on hpdv1000
You could have a broken power socket where the charger plugs in to the laptop. If the battery is flat and the socket is broken or loose then it wont charge and will be completely dead. If the socket is ok then it should power up with just the charger plugged in, even without the battery plugged in. You could also have a broken wire in the plug on the charger, the end that plugs in to the laptop.
Feb 01, 2012 | HP Pavilion dv1000 Notebook
My phone wont charge
there could be many reasons for such a problem, charger related , and device related, so you have to check the following:
-first, you should check the power socket, it might be the reason why the charger is not charging your mobile phone.. try to insert it to many several power supply sockets..
-second if you tested it and it did not work; the charger itself might be broken, try to attach it to another mobile phone and see if it will charge or not, and try another charger to be attached to your mobile phone so that you will figure out if the charger is broken or not..
-third, assuming the charger is perfectly functioning, it is more likely that the battery is dead, every rechargeable battery comes to an end someday not able to be recharged having its chemicals consumed or changed, so that the easier way is to be replaced.. BUT, if you put that battery in a similar compatible mobile phone then tried to recharge it and found out that it is been recharged successfully, that means one thing that the charging port (where you connect your device with charger) is malfunctioning or broken so that it does not joint the charger with the battery..
Mar 26, 2011 | Cell Phones
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Charger socket broken
That little black thing goes into the charger so without it, or something to replace it, you can not charge, unless you somehow found a way to take out the battery and charge it outside of the ds. I would highly recommend sending it back to Nintendo or something like that.
Jan 24, 2009 | Nintendo DS Console
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Cigarette lighter sockets no power
Cell phone chargers commonly blow the fuses at the power points. It seems that our charger adaptors do not match the socket properly, and the positive part of the charger hits the negative of the socket, resulting in a blown fuse. If you have a charger, and it works, leave it in the socket. Don't take it with you. Repeated insertions of the adaptor to the socket magnifies this issue.
Jul 16, 2008 | 2002 Toyota Camry
Samsung SGH-t629 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
