Question about Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier
My kicker kx 1200.1 keep clicking to protection mode back and forth when it power. There is a clicking sound comming from the amp...is it a major problem to fix? This just start happening when i was listen to music in the car (normal volume) and all the sudden the bass stop and it just comes on back and forth just like the amp.
  • 776 Answers
Look for a frayed speaker wires. Look everywhere. Start where you can see and then look under carpet, under seats, trunk and everywhere wires go throgh a hole in steel frame. Any minor connection between the two speaker wires will cause high-power systems to go into protection mode. Wires can be damaged by long-term vibrations of your car, people stepping on badly placed wires under carpet, moving seats (when adjusted) or even rodents bitting on the wiring. Look closely and you will normally find it. Also look closely where you connect your speaker wires to the amp. One small strand of wire jumping across to another terminal will cause a short and cause protection mode.
Posted on Nov 19, 2009
    President:
  • 1,126 Answers
Recheck amp to speaker wiring.....normally, protection mode means that there is a short circuit (fault) on the output to speakers. Try to find it quick, before it stops coming back at all.
Kicker kx850.4 protection light stays on know power light
Check power make sure you have solid 12 volts. Disconnect speakers, shorted speaker can cause protection mode to engage. If still in protect mode will need to repair. Kicker does out of warranty repairs on kx series amps or try T.I.P.S contact at linearpower.com. Iirc Ray @ tips was one of the engineers at kicker back when kx series was introduced.
Jul 19, 2016 | Kicker Car Audio & Video
My kicker amp goes in and out of protection, like when i turn the car on it turns on green then just goes red then goes to green again and goes back to red. I was bumping for awhile and just started hear...
Thankyou for the detailed fault description..it really helps!
sounds like there is one of these 3 things wrong:
1. leaky or partially blown mosfets on ouput power stage of amplifier are leaking DC onto speaker output causing amp to go into protect..this explains any banging or clicking herd.
2. There has been damage to the internal SMPS and is going into protect because of an internal rail over-voltage/under-voltage.
or 3. you have a shorted speaker lead or sub that is bringing the amplifiers load down to less than 2 ohms..buy or obtain a multimeter and have a poke around and check all your speaker leads on the ohm setting anything lower than 1.6 ohms and you have a short...also make sure that you have correctly loaded amplifier to..alot of begginer audio enthusiats overlook this important step and cook amplifiers!!
remeber impendance ratings, have a look on google, search "impendance formulas" and study up if your unsure!
hope this helps,ben
Sep 30, 2010 | Kicker (ZX750.1) Car Audio Amplifier
My amp kx1200.1 works only 5 minutes and then getting real hot somebody have any idea
You need to swap your main battery for a high performance kinetic... and maybe even ad a small kinetic in the back as well (fused separately) and see how that works for you. Just one oversized kinetic battery replacing your stock battery may do that trick. Remember, its best to install two batteries of the same brand and size, its ok to use the same brand and two different sizes (a kinetic 2400 and a kinetic 600 for example, but with an isolator) but its easier and simpler to just put in a kinetic 1200 or something that will replace your stock power sucking ineffecient lead acid stuff.
Jul 26, 2010 | Kicker KX1200.1 Car Audio Amplifier
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
I've been running a kicker kx 800.2 and it has worked until now
Hello highryguy420,
It sounds like one or more of the output components is failing on the amp. You can contact Kicker support directly for instructions to return the amp for repair: support@kicker.com . Alternatively, if you have a local car audio shop that does component level repairs, they could perhaps save you some money and time.
Hope this helps.
Jul 14, 2009 | Kicker KX800.2 Car Audio Amplifier
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker kx 800.4
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
Are you sure your speakers are OK?
Nov 04, 2008 | Kicker KX800.2 Car Audio Amplifier
Kicker kx1200
I am having the same issue, my kicker kx 1200 watt amp was pushing two JL Audio W6 12's and amp has power but no speaker out put, sending my amp to kicker for the thrid time. I tryed in my friends car with no luck.
Nov 20, 2006 | Kicker KX Series 04KX1200.1 1200w RMS...
Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier Logo
928 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
