1994 GMC Suburban Logo
Posted on Nov 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reverse won't work on my 1994 GMC Surburban 4x4. Only 90K miles, truck is in great shape otherwise. All other gears work fine. Tranny fluid looks and smell fine, it was changed in the last 12K miles.
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Nov 19, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
24635
Points
186
If you have no reverse, more than likely, you have either a stripped or broken sunshell, assuming you have the 4L60E transmission. Are you absolutely sure you have all forward gears? Another indication of the sunshell being defective, will be no engine braking in manual second.
My 2005 gmc envoy slt 4x4 won’t go into any gear other than reverse and I checked and put a clutch tourque converter code up
Do you have a code number? otherwise more commonly found when you have just reverse is a cracked cage in the transmission,the good thing is it is a cheap fix.
1995 GMC surburban 4wd 454 automatic no reverse and won't disengage when in park
Check shift cable assembly on transmission for proper operation. If cable is working properly, suspect internal transmission problem
1helpful
My 1999 Yucon is not shifting in to reverse now....
You probably have the same problem i just repaired on my surburban. It had 190000 and I lost reverse also. so you may have a reverse sun shell problem. This was common on the 4l60e transmission and when the part wears out you have to have the transmission rebuilt or replaced with a Re-manufactured transmission. Without more information then this is what I can offer.
How do you put on a fan belt for a 1994 surburban?
this has a serpintine 1 peice belt that has a single belt tensioner with a square drive in it you simply push tensioner against spring pressur and carfully hold and slip belt off 1 pulley then slowly let tensioner back to its stop,there should be a belt routong diagram on fan shroud or simply draw a picture of pulleys and belt routing before removal,then reverse procedure quite simple acully
Have a 1998 surburban 4x4 4L60E trans high r.p.m from stop to change into gear want move i reverse can it be in valve body oil flow and pressure?
The late shifting could be a control problem but the no reverse is not. These trans had a habit of stripping out the reverse sun shell, the metal from it may have gotten into the valve body causing the late shifting, but it really does not matter. If you have forward movement, but no reverse it has to come out. Sorry dude. You need a trans.
1helpful
2answers
No rear lights on 94 surburban... is there a main harness conector that runs to the rear section and controlls the rear light from the main harness that might have come disconected. this is for a budy of...
Check ground wire connection from rear light harness connected underneath body in the rear.Sometimes the bolt that grounds the wire to the body of the truck corrodes
1helpful
Drive or overdrive dont engage
sounds like you need the gearbox looked at.... the adjuster pulleys in the in the gearbox are loose.. hope this helps
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
