Question about GPS
GoGo GPS 430 screen frozen in middle of trip Need to "reboot" somehow. Have tried holding down power, removing SD card, etc to no avail.
    Top Expert:
  • GPS Master
  • 80,493 Answers
On the bottom of the unit there is a reset button, depress it, if it is recessed use a paper clip end to do the reset.
Posted on Nov 19, 2009
Firmware
Usually, the Reboot routine is done by holding down the Power ON/OFF button for a while (5 seconds or more) until it reboots. Don't be surprised if it takes a minute or so.
Alternatively, consider using the RESET button ... then do the Reboot routine. Make sure your battery is well charged, remove the SD card, and hold the RESET (pin) down for 20 seconds or so (until the screen shuts off). Then do the Reboot routine.
Jun 22, 2013 | Tomtom Xl 335 S GPS Receiver
Initial logo screen now blue background with vertical colour lines. Glideslope usually moves sideways briefly and returns to center (normally), not now, stays deviated. What is wrong ? If replacement part...
Download and install the latest software update for Garmin GPSMAP 430 :
http://www8.garmin.com/software/ChartplottersUpdatewithSDcard_20120213.exe
Installation Instructions:
Click on 'Download' and choose to save the file to your computer.
Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.Once the download is complete, go to the location where you saved the file.
Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
Power on the device and make sure all other connected devices are powered on as well.
Insert the card into the card slot of your primary device. Select 'Update Software' in the window that automatically displays. If you do not have a primary device with a card slot, please see your dealer.
After the update completes, the chartplotter containing the SD card and all NMEA 2000 sensors will have the latest software. Note: If you have additional chartplotters connected to NMEA 2000, you will have to independently update each chartplotter. After the update completes, insert the update card into each NMEA 2000 chartplotter.
2.Restore your GPS to factory settings:
Note: This procedure deletes any information you have entered.
1.From the home screen,select Configure > system>System information>factory settings.
2.Select Yes to restore all factory settings,or select No to cancel.
If you have questions or need further assistance ,please let me know.
The unit reboots and prompts you to adjust unit settings .
Mar 02, 2012 | Garmin GPSMAP 430 GPS Receiver
720 Go is frozen. Press the reset button and nothing still get the same screen with a harddrive in the corner. Put it in the cradle and the computer doesnt see the unit when it is on?? Have tried to let...
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 20 seconds. The reset button is a hole at the base/bottom of the device.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds or more, until the GPS starts up. It may take a minute or two of holding it down.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Sep 02, 2011 | Tomtom GO 700 GPS Receiver
My husbands tomtom IQ routes edition has just frozen - it shows a picture of a world. What can he do to get it back to normal?
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Jul 10, 2010 | Tomtom One IQ Routes GPS Receiver
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
The screen on my tom tom one has frozen. How can I fix this?
remove the sd card if you have one, then press and hold the power button until it turns off. then put the sd card back in and restart it. if that fails, let me know and i will tell you how to reset it.
Nov 11, 2009 | Tomtom ONE GPS Receiver
Frozen screen
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
Oct 11, 2009 | Tomtom ONE GPS Receiver
TomTom screen frozen/won't turn off
This is usually an SD card issue. If you have one in then remove it and try again.
If there is no SD card involved then the other cause is that files may have been deleted or somehow corrupted.
In that case you would need to try and restore if you took a backup.
I have a spare card with my original tom tom software on there.
You could always try a HARD reset too !
Aug 20, 2009 | Tomtom GO 910 GPS Receiver
Deprogramed
I need more info to possibly help.
Do you have info on the SD card you need to keep?(just use a SD card reader for your computer to reformat to FAT) Be sure to copy all files to a safe place FIRST!
You could also try this combination, to clear ALL memory then reboot GPS unit.
1. Press and hold "Enter"+"Menu"+"PWR"
2. Follow GPS units On-Screen directions.
If GPS unit "locks-up" press and hold keys in this order, "Goto"+"ESC"+"Enter".(Forces GPS unit Off)
good luck
Aug 08, 2008 | Magellan Meridian Gold GPS Receiver
Maps
The C220 comes with an SD card with all the maps. Or an SD card can be created with the included CD
Sep 16, 2007 | Mitac DigiWalker C230 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
