Question about Frigidaire Dryers
Frideraire dryer model fde336res2 won't eat. The
Frideraire dryer model fde336res2 won't eat. The terminal block was bad and I replaced it. It still won't heat- don't know why the block went back but the wiring was frayed and burned. Help!!
  • 464 Answers
Take a look at #36 in the breakdown I have attached. This part is called a thermal limiter and blows if the heat is restricted in any way to cause the dryer to get too hot. You need to make sure that you don't have a lint buildup around the motor and in your vent hose. The part number for this part is 530320912. Hope this helps.frideraire dryer model fde336res2 won't eat.  The - 250
Posted on Nov 19, 2009
Dryer model #GLER642AS3 has no power, won't start.
You may have a bad timer, door switch, start switch, motor or terminal block. You should have a repairman test them all.
May 06, 2012 | Frigidaire GLER642A Electric Dryer
Model 7600ayw won't start. the terminal block
Very likely whatever made the terminal block break caused the internal thermal fuse inside the dryer blow,causing the dryer to now not start. You can get to the thermal fuse which is not resettable and must be replaced by removing the front panel and find the thermal fuse in the housing where the blower wheel is...it will look smilar to this picture oldtech2332_108.jpgfor you exact model the part number is 306604 and the terminal block with should also be replaced is 400008 they could be purchased at your local appliance parts store or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 14, 2011 | Maytag Dryers
DRYER WON'T START NEED PROPER ELECTRIC WIRING CONFIG
red and black conductors to L1 and L2 on dryer terminal block,the white goes to the N or Neutral terminal (normally between the L1 and L2 terminals),then the Green wire connects to the case ground screw or the metal dryer case
Sep 14, 2011 | Dryers
Frigidaire model FDE336RES2 makes a squealing noise and won't turn with a full load in dryer.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Dryers
I bought a used dryer (model # fde336res2, serial # xd01501804)The dryer works, needs a knob but it also eats my clothes. It seems to be a problem between the barrel and the front panel. The clothes get...
Your problem could be caused by a bad felt seal..the drum rotates against this seal. The purpose of the seal is to seal the hot air from going out of the drum and into the room.
Remove the front of the dryer and this should expose the drum and felt seal.
Sep 25, 2009 | Frigidaire Dryers
Dryer will not heat up
check that you didnt disturb any wireing by mistake. then chec the contunity on your heating element. they are actually pretty fragile.
Apr 25, 2009 | Frigidaire FDE336RE Dryer
Dryer stopped heating. I replaced thermostat and heater element. Did no solve problem. I checked voltage at heater. I have 120 VAC on both sides. When I check total voltage from both sides I have 1 VAC....
YOU HAVE A BAD BREAKER OR A BAD CONNECTION AT THE TERMINAL BLOCK AT THE REAR OF THE DRYER. CHECK VOLTAGE STARTING AT THE TERMINAL BLOCK. IF 240 IS PRESENT THEN PROB IS IN DRYER IF NOT, BAD BREAKER
Apr 07, 2009 | Dryers
Loud thumping noise in Frigidaire model # FDE336RES2
You have to remove the top lid. Then remove the front panel. Then remove the belt and drum.
Your problem is a bad rear drum support assembly.
Remember to unplug the dryer.
Mar 27, 2009 | Frigidaire FGR341AC Electric Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
Replacing a defective Terminal Block - Kenmore Dryer
If there are any lose wires connected to the dryer terminal block and there is any sign of current draw like black around it or if it just looks bad in general then yes it does pose a threat of a fire hazard or electrical hazard like shocking you when u touch the frame. There is a terminal block you can buy for it visit any part place with the model number and they can help you out hope this helps
Jan 08, 2007 | Kenmore 64892 Electric Dryer
Dryers Logo
152 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
