Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
How do you take the bulb out of the television
    President:
  • 1,284 Answers
The lower front panel has to be removed first. After that is removed there is a door almost in the center of the TV which has to be removed then the lamp is behind that. If you need instructions you can download the owners manual at the Sony website. Please take a few moments to rate my answer. Thank you
Posted on Nov 19, 2009
How to replace bulb?
Either under the front long cover--or on the left side. Most HIt LCD projos use a P22H 120 watt bulb, get a phillips bulb and you will be happy. Ebay sells these all over the place.
Apr 28, 2014 | Hitachi 60FX32B 60" Rear Projection...
How to change a projection blub
Hello
To chage the bulb in a projection tV do the following
1. Turn off the television. Let it sit for 5 minutes.
2. Unplug the television from the power socket. Let it sit for 30 minutes to 1 hour.
3. Unscrew and open the door that covers the projection bulb. You will usually find this door near the outlet wire. It may have up to four screws holding it in place, usually Phillips-head screws.
4. Pull out the bulb. There should be a plastic handle that you can gently pull out to remove the bulb.
5. Remove the new lamp from its packaging without touching the glass of the bulb.
6. Line up the groove on the new bulb with the groove on the bulb housing in the television.
7. Gently push in the bulb until you hear a click.
8. Screw the projection door cover back into place, then plug in the television
OK
Mar 19, 2011 | Sony Televison & Video
I think a bulb is out how would you know?
Look into lamp, you'll see a glass cylinder with a bulb at the bottom. White or black buildup inside means bad bulb. Also the spherical bulb can deform by heat - bad bulb as well.
When you replace a Panasonic bulb you must reset the lamp timer.
Jan 17, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have a 56 hd-56g787 and it poped the other day, I instantly unplugged ,pulled the sid cocer off and now have a blown bulb.Will changing bulb fix my prob ?
Yes,if the bulb it ur only problems.Change the bulb.Tries websites like Partstore.com,Ebay.com to buy a new bulb.
Aug 30, 2010 | JVC HD-56G787 Television
Bulb keeps going on and off . does that mean the bulb is going bad
If TV shuts off and turns On itself again then yes, bulb in TV is weak and need to be replaced.
Please buy Sony oirignal bulb/ lamp for your TV safety.
Lamp/ bulb replacement procedure would be written in user manual.
Thanks.
Jan 01, 2010 | Sony KDF-E55A20 55 in. LCD Television
Bulb repacement on Enerson mw8992sb, how do you
Your television doesn't have a bulb, it has a picture tube.
Nov 24, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Bulb
You would have to remove the back of the television board and there should be a black plastic piece that covers and protects the bulb inside the television. I would recommend that if you are not a technician please have an experienced person replace your bulb.
Aug 04, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Replacement bulb
There are numerous sources on line which will find the right replacement bulb based on your model number.
Jun 14, 2009 | Toshiba 52WM48 52 in. HDTV-Ready...
Bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
