Question about Protron PLTV-32 Television
My tv won`t go on, maybe a fuse blew [if it has any fuses]can you help? I`ve heard lcd tvs have fuses.i went and bought another tv, I do`nt know if it`s worth paying to get it fixed at a tv repair shop .the tv that won`t turn on is a {protron 32'' lcd}
  • 975 Answers
YOU MIGHT BE ABLE TO FIX IT YOURSELF if your handy with tools , if not then to a tv repair shop , hope it helps ,AJ
Posted on Nov 19, 2009
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Jan 02, 2018 | Mitsubishi WD Televison & Video
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
It went off on its on and won't come back on. It just popped off while I was watching it.
It likely blew a fuse. However, TVs rarely blow a fuse for no reason. I recommend getting it fixed. You can try a new fuse of the same size, but if it blows, please get it repaired. DO NOT put a larger fuse in - fire hazard. The fuse maybe solder in.
Apr 21, 2010 | Televison & Video
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
Fuse Blowing
A blown fuse is usually caused by a shorted regulator or a bridge rectifier circuit. Either way it is a problem in the primary power supply. A bad cord won't blow the fuse in the set, it will blow a circuit breaker in the house. A servicer usually would normally cover the inside of the set with a "few light slits in the AC cord". Hope this helps
Jun 02, 2007 | Sylvania 6626LCT 26 in. LCD Television
Not turning ON, fuse blows.
In most cases, it is either a shorted component in the power supply or a shorted horizontal output transistor. It will take experienced electronic troubleshooting to fix it. TVs have lethal voltages (both 110V and 25,000V kind) and improper repair can result in shock, injury, or the emission of X-rays by the TV! Be safe and either replace the set or have a shop work on it for you. I'm a tech with over 25 years of experience, by the way. I appreciate honest rating of this reply if you find it helpful.
Nov 13, 2006 | Daewoo DTQ-25S2FC 25" TV
Protron PLTV-32 Television Logo
510 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
