Question about SIIG SoundWave 5.1 External Sound System
My computer sounds don't work help me find my audio devices
    Guru:
  • 1,738 Answers
Make sure you didn't accidently hit the mute button.
Posted on Nov 20, 2009
2 Suggested Answers
Paeroa
  • 457 Answers
SOURCE: No audio device
Here for the drivers
http://drivers.myfreewares.com/driverdownload.php
Posted on Oct 16, 2007
Audio service not running
Hello.
It's a possible problem with the driver or the sound card may bedisabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer,http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer.
Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
~~Hope this helps. Glad to be of service.~~
Dec 06, 2011 | Dell Computers & Internet
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
Nov 23, 2011 | Dell Computers & Internet
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I can't seed to get my speakers to work. I have UBL pro speakers.
1. Check the Audio icon on the task bar if muted. If yes Unmute Go to start > control panel > sound. and make sure that nothing is muted.
2. Sound Diagnosis refer this photo
3. Re install the audio drivers. LINK
4. If steps 1-3 don't work, then take your speaker to your friend's computer and see if it works there? if yes then something is wrong in your computer system, if no, then something is wrong in those devices.
Refer to this image below. From your speaker the 3.5mm jack should be plugged at back of I/O ports LINE OUT.
Thank you for posting hope this helps..
Jul 06, 2011 | Computers & Internet
My hp pavillion a6703w had sound but all of a sudden now sound! I tried everything to fix. Device manager says it is working, but when I go to the speaker picture on the screen it says no audio device is...
take the disk your computer came with one might say recovery disk or drivers disk depending on what you have. and install your audio driver, you might of deleted it by accident, it happens. Please vote for me helping out
May 10, 2011 | Computers & Internet
No sound
no sound mean:
1- speaker is bad
2- entrance sound is bad
3- driver is bad ( re-nstall)
4-windows had a damged files (re- install)
5- sound ic control is damaged ( need out pci/ usb sound card )
6- tow jumper in mother board are take off
if you see these answer helpful please don't forget to vote me
best regards
Apr 25, 2011 | Computers & Internet
My speakers work fine. I don' t know why thay keep turning. i have the internet. How do i keep my speakers on all the the
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 16, 2011 | Audio Players & Recorders
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
Please Help. I hv HP Compaq dc7600 Convertible Minitower PC Sound Problem.... control panel--->sound and audio devices-->No audio device
well first after turning the computer on, immediately press F10....go to security and check if the audio is turned on (not invisible) if it is go to pci devices and check there if the sound is enabeled, don t forget to press F10 to accept values and reboot the computer goodluck
Oct 17, 2010 | HP Compaq dc7600 Convertible Minitower PC...
SIIG SoundWave 5.1 External Sound System Logo
29 people viewed this question
Top SIIG Computers & Internet Experts
k24674
Eric Sutherland
Are you a SIIG Computer and Internet Expert? Answer questions, earn points and help others
