Question about Uniden 2.4 GHz Cordless Phone System
Every phone has handset
Every phone shows on the handset "Out of range". and none of them will work
All four phones showed "Out of Range" I unpluged the main phone - the one with the telephone hook up. I left it unpluged for a few minutes, plugged it in and IT WORKED> Thanks for your interest in helping me.
JJS
Posted on Nov 19, 2009
How do I link handset to base after power outage CS6529-3
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
Feb 19, 2015 | Lands Phones
New cordless phone showing out of range
Check that it is registered with the base station and check the range coverage. If you are not out of area of coverage and handset is properly registered to base station then your handset may be faulty.
Dec 12, 2014 | Lands Phones
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
I have uniden cordless phone model dxa15588-2, how do I register handset on base?
1-Press the hangup key (represented by a red phone) and the "#" key at the same time for at least five seconds.
2-Select "Deregister hs." Choose the handset and press the "Select" key (which also shows an envelope for messages).
3- Choose "Yes" to confirm deregistration. The phone clears its registration information from the base and deletes the link from its memory. The message "Handset not registered -- place handset on base to register. See owner's manual for help" now shows on the display. If you are out of range of the base, "Out of range" shows.
4-Place the handset in the base charging cradle. The phone automatically selects a new security code from those stored in the base.
5-Make sure your phone is working again after "Registration Complete" shows on the display
Hope this will Help. Thank you for using Fixya !!!
Nov 17, 2010 | Uniden Cordless Phone
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
I have a three hand set GE dect 6.0 one of the handsets will not activate, it keeps showing me "Out of Range" I have tried many times to set it up but it always give me the same message "out of range". Can...
On the handset, look for the "PROGRAM" button and choose "HANDSET SETUP". Scroll through the menu to find "REGISTRATION" and select it. The handset display should then prompt you to press and hold the "PAGE" button on the base unit for 5 seconds and then press the "PROGRAM" button on the handset.
Perhaps you've already tried this process, as you indicated your attempts "to set it up". This is what worked for my GE DECT phones when one of the handsets displayed "Out of Range" after an electrical storm. Best of luck to you!
Jul 09, 2009 | Thomson GE 27907GE1 Cordless Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Uniden 2.4 GHz Cordless Phone System Logo
309 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
