Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Just got MCC4516F chainsaw.Used it for 30 mins. Stopped working. Chain brake does not engage or release. Chain does not move. Motor runs but will not engage to make blade move. Seems like chain brake handle does nothing.
  • dontbother10
    dontbother10 May 11, 2010
    Brand new unit with a problem... why aren't you where you purchased it?
    Problem Solver:
  • 27 Answers
You have obviously jammed or broken the chain on the inside of the motor. Take it to be repaired, or try reparing yourself by opening up the engine casing yourself.
Posted on Nov 19, 2009
Motor runs chain wont turn
Is the chain brake still engaged.? pull bach the front hand guard to release the chain brake.
Is the chain too tight on the bar.?
Mar 18, 2015 | Garden
Chain won't move when motor running
Sounds like the chain brake is on, grab the hand guard and pull it firmly back to the top handle to release the brake.
Aug 17, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Chain will not move on chainsaw
Is the chain brake set? Make sure that the chain is not adjusted too tightly. It should be set so that the chain doesn't droop from the bottom, but allows the chain to be moved freely by hand. The chain teeth should cut toward you on the bottom. Check the chain oiling by running the saw tip near to paper or cardboard--it should leave a thin line of oil after a few moments of running. Hope this helps!
Mar 27, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
With the chain off the device, I start the engine
Is the Chain brake engaged? It's the plastic "guard " in front of your left hand.
Apr 21, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain brake problem
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
This is the breakdown of parts for your model,you can see how the brake is, but your problem sounds like the dogs inside the clutch are stuck and causing the chain to constantly engage the chain.
Open the clutch to look at it and see what is causing this.
The idle usually will not cause the clutch to engage, this is usually
a higher rev that engages the clutch.
Apr 14, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
272 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
