Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
My westinghouse tv wont turn on.the power indicator doesnt illuminate. i made sure the power cord is secure and used a voltage tester on it and it the cord is getting power.is it a blown fuse or something?
  • 975 Answers
THAT COULD BE IT , a BLOWN FUSE , have to open unit and check the power supply , hope it helps , AJ
Posted on Nov 19, 2009
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Why wont my 46' westinghouse lcd hdtv turn on?
If it's not a fuse in the power cord, is it possible that there is an issue with the wall socket?
Failing that, I'd look into getting a replacement either by purchasing a new one or through a warranty claim
Jul 24, 2014 | Westinghouse LTV-46w1 HD 46 in. LCD...
Westington tv wont turn on
My tv is a Westinghouse**** Sometimes i move the tv slightly and the cord partially comes out at the side and i just push it in all the way and all is ok
Nov 30, 2013 | Westinghouse 46" Class LED-LCD 1080p 120Hz...
My westinghouse "46 wont turn on...is it the power supply and can I replace it
It sounds like the power supply is having an issue. Yes its easially replaced no special tools required just a screwdriver. You can get the power supply board from www.tvcircuitboards.com
Feb 10, 2013 | Westinghouse TX-47F430S 47 in. LCD TV
The tv wont power on at all
Your TV Won't Turn On
If your TV won't turn on, you should check the power cord. Make sure that it is securely in the wall plug. Sometimes the power cord has burned out and needs to be replaced. You may also want to check the batteries in the remote to make sure that they are working properly. If otherwise
Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, if otherwise, Power supply board just die.It can be dead at anytime.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
I hope this will help to solve the problem.....
Jul 07, 2011 | HP Pavilion MD5020N 50" DLP HDTV
I lost my tv power supply cord my tv is 110-240 can I use a 10a 125V cord from my computer that fits in my tv (to replace the one I cant find)?
No,tries websites like Partstore.com,Amazon.com,Ebay.com to buy the right power cord.They're different cords tv power cord 110-240 voltages.The computer a/c power cord 10 Amp to 125 voltages.Don't try it,will burn somethings on the tv.
Sep 17, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My dell lcd tv is not turning on
When turned on, the power indicator light should illuminate. If it does not, verify your power source at the wall outlet and at the TV power cord input. If you are using the remote control, make sure the batteries are good. The TV will have a power button built in. Try to turn the TV on there to verify the remote's operation.
Also, ensure the input source is set correctly; not to Aux or Computer or the like. It must be set to the correct TV input.
If these don't do the trick, you may have a bad TV and need to call Dell.
Nov 23, 2009 | Dell Computers & Internet
I have a Westinghouse 26" tv SK-26H730S sometimes the tv doesnt turn on sometimes. seems theres no power. i changed the power cord same results.
Hello, it seems like you need to replace the power board on this unit, you can find the part by sending a request to parts@wde.com, please make sure to include the model#, serial#, and TW#, all located on the back of the unit. You can also ask to have a technician give you a call so he can assist you a bit more on how to go about changing the power board.
Nov 21, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
341 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
