Question about Echo Garden
Dropped my echo cs-3000 ignition coil wires came apart and wires to on/off button. which wire goes where?
    President:
  • 2,220 Answers
EchoUSA
http://www.echo-usa.com/faqs.asp
#2,
then line 2 "Operator's Manuals/Parts Catalogs/etc."
Click "CS3000"
Toward the botom is the "Parts Catalog", choose the "Ignition, Starter Assembly" detail.
Item 4 connects between the coil and the on/off switch.
HTH
Lou
Posted on Nov 19, 2009
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do you fix an Igniter Circuit Malfunction - No. 1. (P1300) on a 2001 Toyota echo?
The problem 95% of the time is an ignition coil, if you do not have special equipment, your only tool is common sense, disconnect plugs from spark plugs, remove spark plugs,now insert the plugs in the wires and set them together touching metal ground them,
Ask somebody to crank vehicle one of those wires or 2 of them if the coil is bad wont fire or the spark will be weak and orange, blue is ok. Follow the no spark or weak spark to the coil, now swap coils , repeat the same procedure if the problem follow the coil to the wires that were ok before the problem is the coil if the problem is still in the same position the problem is harness wires or computer.
Jan 16, 2011 | 2002 Toyota ECHO
My cs-3450 saw has no spark. the ign wire shows to be grounded. bought a new coil, still no fire. the ign wire on this coil also shows to be grounded. what is the problem?
disconnect the on /off switch that is how it gets grounded so that it will shut off may be a bad switch disconnecting it will allow it to start.
Nov 14, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I have a cs 4000 ser 00135 series that I am unable to get a spark... I replaced the coil, magneto, plug, flywheel is good... is there a ground somewhere that I am missing?
The ignition switch or it's wire to the magneto might be worth looking at. Remove the switch connection from the magneto to see if you can get spark. The switch grounds the magneto circuit when it is set to 'off'. Good luck!
Sep 11, 2010 | Echo Garden
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Echo 550 EVL is not firing, any ideas
Replace the plug and do this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
You can find parts here:
EchoUSA
http://www.echo-usa.com/documentation.asp
If not listed type the model number in the “Model:” window and click Search.
Your model is CS-550EVL (see page 3). HTH
Lou
Feb 15, 2010 | Echo Garden
How do I change the primer bulb on my Echo CS-3000 chain saw
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Sep 06, 2009 | Echo Garden
Garden Logo
248 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
