Question about King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
I have a 6' Kingkutter and the gear box bolts securing to deck are coming loose from deck. How do I get to the nuts to tighten box to deck.
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What will cause the bolt and nut for the blades to keep coming loose?
This is usually caused by one of two things. If you have the right size bolt,put a lock washer on it and tighten until the washer is flat. If it continues to work loose you should check for the proper bolt size/ threads or the threads in the bolt hole could be worn out
Jul 02, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Gear box filler plug
glue or weld the head of a bolt to it.then use two nuts on the bolt tighten both of them now a ring spanner on the first nut as is held by the second nut.
Dec 16, 2013 | 2005 Nissan Sentra
How do I fix manual steering play?
Is the play in the steering wheel or in the actual suspension? If the looseness is in the wheel i would recommend changing out the steering gear. if the play is found in the suspenion system you will need to replace any part that is loose. i hope this helps
Feb 28, 2011 | 1992 Toyota Pickup
Deck only raises a little bit, not the way it is supposed to. Selections 1-4 is the same level, resting on the ground. how do i fix this
The bolts or wing nuts for the deck adjustment have likely come loose or off entirely from the raising/ lowering undercarriage.
Once you have identified the loose or missing nuts (and replaced, making sure to add lock washers) then move the mower to a flat, level surface and move height lever to the lowest setting (some mowers have a flap over an ultra-low setting for this purpose).
Now tighten the nuts on the raising / lowering arms. You should now have normal control over the height. Farmerbear at FixYa.com
Sep 28, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steer wheel assembly.steering loose between wheel and tilt assembly.
Hello Kimkaye.
There are three bolts that have come loose and will need to be tightened.
Some special tools will be needed to disassemble in order to access these bolts.
I would recommend a professional to do this job for you as there are many parts and pieces to contend with in this job along with the supplemental restraint system (airbag).
Apr 29, 2010 | 1990 Oldsmobile Cutlass Supreme Conv
Rear window loose
Check with Ford for recall info. There were a few years the rear window hinges were defective and recalled.
Mar 24, 2010 | 1999 Ford Explorer
530 exc spacing between front fork & spacer
front axle installation: looking at the front of the bike:
slide the wheel into position and insert the axle from the left. with axle now through the right hand fork, install nut and tighten the left fork pinch bolts to secure the axle for tightening the nut. tighten the nut to 29.5 ftlbs. and loosen the left pinch bolts. now tighten the right pinch bolts and compress the front suspension while the left (from front) is still loose. now allow suspension to rest naturally and tighten all 4 pinch bolts to 11 ftlbs.
your done.......the axle is tighten against the rotor side and the other fork is then tighten in it's natural position so as not to cause premature seal and bushing failure and increasing stiction.
Sep 27, 2009 | 2008 KTM 530 EXC-R
Far to much steering wheel play befor tire reaction
Loosen nut on top of steering gear box. Tighten adjustment bolt 1/4 turn at a time then tighten nut. Drive and see if it hold together better. Repeat until you can't tighten adjustment bolt any more. If it's still iffy, replace your steering gear box.
Apr 11, 2009 | 1997 Jeep Tj
Pulley on alternator comes loose
souds to me as though the bolt is shot, and possibly the thread in the shaft. If this has happened again after correct attention you should be seriously looking to strip and rebuild, even Locktight wont heal "wobbly gear shafts".
Mar 24, 2009 | 1998 Triumph Trident 750
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
112 people viewed this question
Top King Kutter Tools & Hardware - Others Experts
john h
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
