Question about Dual XDVD8182 Car DVD Player
I am using the Dual xdvd8182. When I turn on the radio, the screen will not work when it's fully up. It will only work if it's tilted enough that I can not see the screen. When it is fully up the screen will be off but the touch capability will still be working. Does anyone know what can be the problem?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dual Master
  • 2,226 Answers
Sounds like you may have a bad flexible cable that goes from the main board to the monitor. you will have to send it to dual to get it repaired.
Posted on Nov 19, 2009
I have a dual xdvd8182 and theres a password lock on the screen. Ho w do i fix it please
Power off then press volume down and power button at same time
Jun 11, 2017 | Dual Cell Phones
Dual XDVD8182 dvd code
ground the green wire at the wiring harness at the back of the deck but first try setting the e-brake and the code well u just (hold) the next track button 15secs and it should just go past
Mar 10, 2010 | Dual XDVD8181 Car Video Player
The parking brake on my xdvd8182 doesn't work, im thinking a broken wire. Ive tried the codes, grounding with a switch and hooking up to e brake
It is illegal and unsafe to watch the monitor while driving. I assume this is needed for an RV or something.
STEP ONE. Ground the E-Brake wire.
No matter which method you use, you must ground the brake detection wire. I suggest you tap it into the ground wire on your wiring harness (ensures a good ground).
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
Have recently heard complaints of this method not being permanent, as this is needed everytime they want to watch a DVD. Also, radio and screen angle presets are lost.
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
Feb 24, 2010 | Dual XDVD8182 Car DVD Player
Load a cd or dvd it just give no disc
I Have a dual XDVD8182 and i want to get a lense for it dose anyone know were i can get the part...
Mar 31, 2009 | Dual XDVD8182 Car DVD Player
I need a Dual xdvd8182 code for vido play during drive and a e-brake override code please thanks
Ground the emergency brake wire,i used the black wire.
Insert an original DVD and let it play until you hear the sound.Copied DVDs will not work for this.
Press the STOP button TWICE with the remote.
Using the remote enter 26604 and press enter.If done you shoul hear it beep and the video will be viewable.
Mar 24, 2009 | Dual XDVD8182 Car DVD Player
I need help with my dual xdvd8182 player
1 Ground the emergency brake wire,i use the radios black wire to ground it.
2 Insert an original DVD and let it play until you hear the sound.Copied DVDs will not work for this.
3 Press the STOP button TWICE with the remote.
4 Using the remote enter 26604 and press enter.If done correctly you should hear it beep and the video will be viewable.
Mar 24, 2009 | Dual XDVD8181 Car Video Player
Dual xdvd8182
Try doing the following:
1. Find the reset button on the unit and press it down for 10 seconds.
2. Disconnect the battery for at least 30 minutes then reconnect.
These simple options usally work. If not you have a faulty unit and its possible that it has been damaged by condensation from the a/c. Ive seen it a good many times especially in Honda's.
Mar 20, 2009 | Dual XDVD8182 Car DVD Player
I have a Dual xdvd8182 code for video play during drive
try this we dont have the same dual model but the code isnt for my model anyway. put a dvd in the player and after it comes up with the warning screen when you start to hear sound hit stop twice on the remote and then press 26604
then just find the parking break override menu and turn it to on
important. you must ground out the wire and take the switch out first! hope this helps.
Oct 10, 2008 | Dual XDVD8181 Car Video Player
Disc does not load keeps ejecting disc
clean the player
the track that the loader runs on is dirty, hists the dirt and reverses to prevent damage
Sep 20, 2008 | Dual XDVD8182 Car DVD Player
Dual XDVD8182 Car DVD Player Logo
166 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
