Question about Amana 24 in. DWA33A Built-in Dishwasher
Dishwasher arms not turning, they are free to spin but no action
  • 464 Answers
Are you sure you are getting water into the machine? There may be something stuck in the impeller, you could check this out. Here is a breakdown for you to look at. Hope it helps.Dishwasher arms not turning - 250
Posted on Nov 19, 2009
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
ned_san_jose
  • 230 Answers
SOURCE: dishwasher fills but arms wont spin
It sounds like the motor is locked.
Take the bottom panel off and unplug the unit.
You will see the motor in the front. Put a screwdriver in the fan and try turing it. If it feels like a lot of resistance, keep trying to turn it. If it doesn't turn after a few minutes, then the motor needs to be replaced.
Good luck.
Posted on Sep 21, 2009
stewbison
  • 577 Answers
SOURCE: Maytag free standing dishwasher.
Hello, look at the little holes in the spray arms and see they are pluged. If so, clean the holes wiith a small pick. There are chemicals that can be run through your dishwasher to keep the hole and other stuff from pluging up with scale. I hope this help you. GB...stewbison
Posted on Sep 23, 2011
Top spray arm does not turn during wash or turns slightly..it is free of clogs and spins freely by hand
It will spin freely by hand, but needs to spray water out of the jets at the trailing edge of the arm. Check inside the arm for blockage and make sure that water is getting to the upper arm from the pump.
Feb 13, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
The arms on my kenmore dishwasher do not spin.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Feb 08, 2011 | Kenmore 17252 Free-standing Dishwasher
The middle arm on my Evolution dishwasher isn't spinning - the top and bottom one seem fine. Glasses especially on top shelf aren't getting clean at all (obviously!). Any suggestions?
Check if the holes are blocke dwith dirt the arms spin by newtons law that every action has a reaction (like a rocket) if the holes are blocked it wont spin as there is no force.
Dec 29, 2010 | Dishwashers
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
Upper arm dose not spin
have you checked to see if the arm spins freely if you push it
Apr 13, 2009 | Beko 24 in. D3421F Free-standing...
Dnby dishwasher slow...
hmmm..empty it entirely...check for any obstructions, and then, you'll need to have a service professional look into it..sounds like it's motor for arm
Mar 15, 2008 | Danby DDW496W Free-Standing Dishwasher
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Bottom wash arm
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
Jul 08, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Amana 24 in. DWA33A Built-in Dishwasher Logo
139 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
