Question about LG 42LC2D 42 in. LCD HDTV
Yellow line down side of screen 42inch lg plasma
    President:
  • 1,284 Answers
If the line is only a pixel in width, then I suspect the LCD panel is at fault. If out of warranty then in most cases the cost to repair it will exceed the cost of replacing the TV. Please take a moment to rate my response. Thank you.
Posted on Nov 19, 2009
2 Suggested Answers
  • 45 Answers
SOURCE: i have an lg 42inch plasma and now a vertical blac...
I had the same problem with a five year old 50" LG Plasma. I fixed the problem with a 11 dollar soldering iron from Radio Shack and about 2 hours of my night. You have to open the back of the tv and locate where the ribbon strips are attached to the screen. I beleive that on your 42" they will be on the bottom of the tv. Mine had 11 on top and 11 on bottom. Yours will probably have around 7 or 8 along the bottom. Mine was a little easier since I did not have to remove the control board. You unfortunately probably will have to remove it. It is not hard at all, just takes more time. Make sure to keep your screws seperated and remember where everything goes. On bigger jobs some tape and a marker are very useful. Put tape on the board and around the wires removed and leave a tail. This way tou will remember to hook them all back up. Once you find the ribbon strips you have to remove them one by one and look at what is behind the metal place. There will be 4 capacitors and 4 resistors. The tv manufacturers want you to buy new tv's every 5 to 10 years so they use a very cheap solder on their contacts. Use you soldering iron and re-heat the solder to liquify it again and thats it. Allow time to cool on each of the caps and resistors. It took me about 1 to 2 seconds on each side of these parts. I did use a dual wattage soldering iron from radio shack. Its is a 25 and 35 watt iron. I used the higher setting. I have pictures if you would like me to email them to you and show you what I did. Be careful removing the ribbon strips, I broke one of the clips that hold in the ribbon strip. That is costing me an extra 25 dollars off ebay but still for a free tv, its not bad.
Posted on Jun 05, 2010
Grey line down side of screen
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 25, 2016 | LG Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Yellow lines going down the side of the screen
It's a warranty issue. Back to the dealer for replacement.
Dec 27, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
My plasma tv picture is green
take off back panel and adjust the V12(A) adjuster wheel on the power board it adjust the gas flow to the screen is should light up your screen
Sep 30, 2007 | LG MZ-42PZ14 42 in. Plasma Television
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42LC2D 42 in. LCD HDTV Logo
1,054 people viewed this question
