Question about Frigidaire GLER642A Electric Dryer
Changing the belt on Frigidaire GLER642
Belt broke on dryer and need to know how to get the top off and access the drum to replace belt. See hinges on back but cannot get the front to pop up.
  • Alain17 Feb 19, 2008
    I opened it, took the old broken belt, but I don't see or know hoa to put the new belt on the drum.. When you face the drier, does the belt be put in front of the drier or behind. Do I have to take something apart.
    You can anwer a my e-mai. amuggler@yahoo.com Thanks for help.
  • pwhite7408 Mar 13, 2008
    I have the same dryer and it smells like it's burning - I was told to replace the belt - now we have to figure out how.
    President:
  • 1,314 Answers
Ok here we go facing the drier take a putty knife come about 1-2 inches from the edge and push in should feel a spring clip depress in lift one side then the other look inside on the front panel and remove the two 5/16 inch screws grasp the front and snap it off give it a good tug then your ready to go be sure to un plug the drier and slide it out from the wall so you can tilt the top back before removing the front don't forget my 4 boxes and make sure the idler pulley is on the belt the the belt goes around the drum around the motor pulley then you pull the idler pulley back and put the belt on top of the idler pulley let it back against the belt to keep the belt tight you do not have to remove the drum for this can all be done from the front
Posted on Jan 11, 2008
Dryer heats but won't tumble
More than likely it is the belt. The dryer has a motor that drives the drum usind a rubber belt that has probably broken. It is fairly easy to replace. Take top off dryer by lifting up top in front, (should be hinged) then you will see if belt is on or broken. Go to local appliance store with make and model number from your dryer and then you will have to lift drum out of case and put belt around it and replace. if you cannot reach belt to put around motor from top you will have to remove back access panel. Put belt on motor and dry away. Good luck.
Feb 23, 2011 | Whirlpool Dryers
How do I change my dryer belt on 1994 MAYTAG dryer?
Assuming this is stand alone front loading dryer, to replace the belt, you access the drum from both the back service access panel and the top. Pop the top at the front corners and it will hinge up at the back.
Reply back with the make and model number of your specific dryer and I can help you more.
Dec 17, 2009 | Cars & Trucks
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
How to install a dryer belt?
Think I can help. Use a large screwdriver "flat head" and pry up the top of dryer. there is a clip on each side on front of dryer. the top should lift in front and stay connected in rear. Prop the top up with something so it doesnt fall. Then look inside twards front and you will see a screw near top on each side. Remove these and the two screws on bottom front close to floor. There is also a ground wire attached to the front with a clip. This can also be slid off with a screwdriver. On some models you have to remove the door. If so just remove the screws that secure the hinge. Now the front should be free. Lift up to remove it. Now you have access to the components. Look in twards motor and you will see a tentioner that keeps the belt tight. Its spring loaded. Push it away from belt and remove belt. Now its just a matter of taking out old belt. Install new belt in reverse of removal. Hope this helps and good luck.
May 07, 2009 | Frigidaire GLER341A Electric Dryer
you will have to take it apart to get the drum out. you have to take the top off
May 06, 2009 | Dryers
Can't Put Belt On
You have to remove the front of the dryer to
access the drum. First unplug the dryer.There are screws at the bottom of the front to remove the lower section. Once you remove that you can get to the screws for the door section. The front of the drum rides on the inside of the front panel so when you remove the panel the drum will drop down. Try to keep the drum in place with something to hold it up. Remove the old belt and place the new belt around the drum. Slid the belt back to where the belt used to ride and then loop the belt around the motor and the tension wheel. Make sure the tension wheel is tightening the belt. Hold up the drum and put the front panel back on. You may need a helper to hold things while you do this. Rotate the drum by hand and make sure it moves smoothly. Plug it back in and give it a try. I hope this helps. Any questions feel free to ask. Please rate me so I know if I'm Helping. Thanks.
Dec 30, 2008 | Frigidaire FEQ1442ES Electric Dryer
Need to know how to replace the belt on my dryer
Take off front and put belt over drum. Reinstall front. Take small access panel off back to install belt on motor. Idler pulley pushes against belt to tension it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Frigidaire FDE336RE Dryer
REPLACE BELT
look to see if you have the little access panel on the back,you can remove this and have access to the belt and pulley system,if not there let me know and we'll try something else-mike
Oct 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer belt replacement
Take the top panel off by slideing a putty knife about 2 inches in at the front and releasing the tabs. remove screws from top of front panel after top removed. also remove 2 screws from inside of front panel on both sides about 4 inches down screwing back into front panel. pull front off and slip belt through opening. Feed belt around drum and put tension on the idler spring release onto belt. reassemble unit.
Aug 09, 2008 | Frigidaire AEQ7000ES Dryer
Belt replacement
I Can help ..... Remove 2 phillips screws under lint filter pull top of dryer forward and then raise like hood of a car Remove 2 5/16 Hex screws holding front on dryer Disconnect door Switch let front hinge down a tiny bit and up and off Belt is routed with idler hinged into base of the dryer 2 slots
Oct 05, 2007 | Whirlpool LER5636P Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
148 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
