Question about Sony Televison & Video
SONY KP-61V90 tv will not power on, red light in front,
Tv will not power on, red light in front, timer/standby blinks red.. blnk blnk pause blnk blnk pause blnk blnk pause...
  • 1 more comment
  • gregjones197 Nov 19, 2009
    thanks, can you direct me to where I can find how to test this?
    can i just replace that whole board? If so, do you have part #?
  • gregjones197 Nov 23, 2009
    cant find whole board.. can you tell me what this part will look like?
  • 10,594 Answers
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Posted on Nov 19, 2009
  • Shahid Electronics
    Shahid Electronics Nov 19, 2009
    Yes, I have required board part number as follows..
    A1316498A... G BOARD COMPLETE (KP-61V90)
    Please search above board over internet for best price, if available because Tv is bit older model.
    Below is an image that shows location of G Board in TV.
    Thanks.
    Shahid Electronics Nov 23, 2009
    Click HERE to see an image of 2SD2578 transistor.
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
When i turn the TV on, a red light on the front of the set just flashes (standby light)
Let me know model and brand of TV if its other then Sony KP-46WT510 and also count red standby light flashes as there would be long pause between blinks.
These info will help me to find out possible solution.
Jul 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
My Sony KP-46S25 TV is blinking red light and is not turning on, please advise.
Please update this with the blink count. The standby light shouldbe blinking a repeated count with a pause. This will indicate the problem circuit and allow me to provide you with the probable defective part(s).
Thanks,
Dan
Jan 07, 2009 | Sony KP-46S25 TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony projection tv model kp-61v90
possible power supply or short on the b+ run,check for shorted horiz. o/p tranistor.
Aug 31, 2007 | Sony KP-61V90 61" Rear Projection...
Televison & Video Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
