Question about Kenmore 24032\24036 Top Load Washer
Model #11026912690 The agitator does not work. The party we are looking for has 3 teeth that fit into another part with 3 teeth with a belt. What is this called? We can't find the part name. Thank you.
  • Anonymous Mar 25, 2014
    timing belt jumped 3 teeth for the second time...what can i do? new timing belt and tensioner been fitted!!
  • 5,911 Answers
Sounds like you are describing the motor coupling. The coupling is located between the drive motor and gearcase (transmission) and takes the place of a drive belt. This configuration is known as "direct-drive". The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included in the instructions I provided. A replacement coupling can be purchased at appliancepartspros.com for about $11 or $12.
You can view an illustration of the part here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893&pn_=285753A
If this is the part you are describing, then you have all the information you need. If you do not wish to purchase on line, take the part number provided and go to your nearest appliance parts retailer. This is a common part that they will carry in their in-store inventory.
If the part is not what you are looking for, please post back and let me know. I hope this helps you.
Posted on Nov 19, 2009
  • 11,896 Answers
You can get a manual and diagram and part names and location at partselect.com
http://www.partselect.com/KenmoreModels.aspx?ModelNum=11026912690&searchTerm=
Posted on Nov 18, 2009
WHAT CAN I DO ABOUT A LOCKED SEAT BELT?
Hi Im presuming by locked you mean it will not move so you can strap yourself in
There are 3 ways to deal with this
1 buy new replacement and fit
2 buy second hand from a scrapers yard and fit
3 strip the casing cover off the seat belt and carefully release the belt trigger that has got stuck you will need to release this first
No amount of pulling on the belt will help, the teeth have to be removed manually from the belt first before you can pull the belt down abit
Put some lubricant on the the teeth trigger down at the bottom usually on the floor of the car on the inside with a case cover over it, this should loosen the mechanism but ifits still too stiff rusty or damaged then you can look at other methods, hope this helps
Sep 05, 2017 | Seat Cars & Trucks
Agitator and washtub don't turn
sounds like the drive belt remove the front panel and look under the wash tub for a broken belt
Dec 18, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Rattling
There are no washers of any sort on the Dyson's agitators. There are molded caps on each end, made to fit into the bracketry on the sides of the nozzle portion. If there's it seems as though there's something missing then you'll need to purchase a complete agitator, there are no replacement parts for agitators.
Nov 08, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Washer doesn't spin nor agitate, the belt is ok so what else could it be and how do i fix it?
Unsure about your spin problem however, I had a similar problem with our machine that it too wouldn't agitate. I worked out that the agitator dogs had worn out. They are four nylon bits that have teeth that fit into the ring inside the agitator. Our 'dogs' teeth had worn down so that they wouldn't mesh with the ring. All I did was search online for an online spares site. Hunted for the type a model and requested the spares. They were dilivered within the week. As an added bonus, they came with instructions that were very simple to use. All I needed was a pair of pliers, a socket set (with socket) and a willingness to get my hands dirty.
Oct 21, 2011 | Washing Machines
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 90 series 11026912690, agitator makes loud noise
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
NOTE: Other causes can include a broken motor coupling, bad gearcase (transmission), or worn clutch assembly. It does not sound like the problem is associated with any of these components however.
If the motor coupling were bad, the washer would not spin at all (whether you held the agitator or not), but would still have the ability to drain.
If the gearcase (transmission) were bad, the washer would either not spin, or may spin with assistance (meaning, if you gave the drum a spin by hand to get it started).
If the clutch were bad, the symptoms would be similiar to that of the gearcase and the tub would probably also have problems stopping.
This problem sounds like it may only be associated with an agitator that could be loose, causing an off balance tub. Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 28, 2010 | Washing Machines
Kenmore 11026912690 washer with problems.
That is the way the agitator works. It actually works the clothes down toward the bottom of the machine. The clothes then do the back and forth agitation working their way back up the outside ot the tub to repeat the process.
Sep 16, 2009 | Washing Machines
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
116 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
