Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printer says no cartridge, but there is
Printer is saying no ink, but there is ink. when I replaced the cartidge, it says 'no cartridge'.
    Guru:
  • 57 Answers
    Sergeant:
  • 309 Answers
I believe you have to press a key combination when the unit powers up to get it to recognize there are new cartridges in place. Check your user's manual on the correct sequence.
Posted on Nov 19, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Printer ask for cartridges
turn off your printer...then replace new cartidges.after replacing cartridge restart printer...always when you want to change or replace cartridge/Drum/fixing/belt trun off your printer...
Jul 12, 2012 | Lexmark X9575 InkJet Printer
Replaced Ink carts on Epson R380 with EPSON ink cartidges - printer says "ERORR: Ink cartridges not recognized'. [?] have replaced these several times in the past with the same type dart with no...
Turn the printer off, take out the cartridges, turn the printer on, reinstall cartridges. Printer reads cartridges as new.
Why this happens? I don't know if the rumors are true but check out this website and you'll find out.
Jul 20, 2011 | Epson Stylus R380 InkJet Photo Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
I put in a new black ink cartridge now it doesnt want to print says ink cartidge is low, its not then just feed paper all the way through
Find out if you have not bought an expired cartridge.Service the printer and replace the cartridges with good quality cartridge.
Jun 02, 2010 | HP DeskJet 9800 InkJet Printer
Ink cartridges
you replace them one for one. There is a piece of tape over the new cartridge nozzle that must be removed first though. It should say on the tape or compare new with old.
Apr 20, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Dell 924 all in one printer cannot remove low ink warning
This happens if you are not using the Dell ink Cartiridges. However there are few work arounds on this issue.
Firstly, Please try to remove cartridges and then clean cartridge slots and make sure that printer is OFF and completed disconnected from Computer. Remove the cable between Printer and Computer while you do this.
After that restart the computer and then try to reconnect every thing and check if this happens
if else, then open the printer properties or printing preferences and locate the option that says Calibrate the cartidges. and do the calibration of cartidges. Calibration is compulsory once if you replace the ink cartidges.
if still fails then reinstall printer software. This should resolve the issue.
Thank you.
Dec 31, 2008 | Dell 924 All-in-One InkJet Printer
Replacement of ink cartridges
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Jan 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Keeps saying to replace cartidge
you have to go int the ink leval thing i think and tell it you installed a new ink cartrige that should fix it
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
272 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
