Question about Seiko SNA311 Wrist Watch
Stopwatch min hand off center
On the stop watch ability the minute had is 4 minutes to the left of the 12 position. How do i get it back to the correct position
    Problem Solver:
  • 9 Answers
The crown needs to be pulled out 1 time and then push the upper button to synch the hand if you have other dials then pull crown out 2 times and push the plungers on the top of the crown and bottom of the crown to synch the dials
Posted on Nov 19, 2009
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Nov 05, 2009 | Seiko SNA553 Alarm Chronograph
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
How do I zero-out the minute hand of the stopwatch?
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If thi do not work, do the same using the button at 4 o'clock.
Rate me, please.
Mar 26, 2009 | Pulsar by Seiko watch PF3359Men's 100m...
Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
Minute Hand on Stopwatch Will Not Return to Zero
Here is the link where you can download manual for your watch:
http://www.seikousa.com/pdf/SNA_Series.pdf
The last chapter explains how to reset hands to zero.
Do not forget to rate, please.
Jan 22, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Setting model number jr3060-59f
1. set mode to CHR with the bezel fully in.
2. pull bezel out 2 notches. This will set all (or most) hands to 12.
3.press A (top button) repeatedly until you get MIN in the left window
4.turn the bezel to move the min hand forward.
4a. turn the bezel several clicks in quick sucession to get the minute hand to continue to move in the forward direction. This will "drag" the 24 hr UTC hour hand froward 1 hour per 1 revolution of the minute hand. if the minute hand stops before you want it to repeat step 4a. continue till the 24 hr UTC hour hand points to 24.
5. to stop the minute hand turn the bezel backwards 1 click. remember however to approach the 12 position with the minute hand in a clockwise direction.
Mar 25, 2008 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Mar 16, 2008 | Watches
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Aquaswiss trax watch
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Seiko SNA311 Wrist Watch Logo
103 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
