Question about Vacuums
It is working but I dont see it cleaning nothing is turning around when it is sucking
  • 701 Answers
If the roller brush is not turning then that means that the belt is either worn, stretched or broken. You need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Posted on Nov 19, 2009
Titan power brush not turning
I had a similar problem,cleaned mine too and it looked clean but what i found was hair tightly wrapped around the spindle under the end rollers so tight you could hardly see them,they were pulled right in and it was a nightmare to remove.Try holding the two rollers and get someone to spin the brushes it should spin with rolling a finger over it.mine was not the same machine as yours but they all work the same good luck.
Dec 07, 2013 | Miele S2181 Titan Vacuum Cleaner
I accidentally sucked up a thin belt that wrapped around the bristles and stopped the bristles and now the bristles wont turn
You need to remove the thin belt from the roller if you haven't already. Check the ends of the roller to make sure there is nothing there stopping the roller from turning. You can try turning the roller with your hand using minimal force.
I believe this unit has a switch on the front of the handle for the brush motor. It may cut off if the roller gets hung up. Have you tried turning this on?
In summary try cleaning everything off of the roller and then check for the switch that I mentioned. Let us know how you make out and good luck!
Mar 13, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Well the hoover seems to be sucking in very poorly and nothing off the floor is being sucked up. how can i make it stronger suction?
u need to make sure that the dust collector is empty and any filters fitted are clean and check the hoover belt if fitted is working
Feb 19, 2010 | Vacuums
My dirt devil is not sucking,i cleaned out hoses and bottom seems to be turning fine?
The fan motor is probably not working. Does it sound normal? Higher or lower pitch sound?
Dec 05, 2009 | Dirt Devil Vacuums
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My rainbow isn't sucking very well and the power head smells like
Hi there SmartAlec from Nelsonvacuums.com.au here. I think that if it is not doing a good job the most likely cause is that the belt in the powerbrush is broken. If you turn the unit on does the brush under the head turn (really quickly). If it does not it will be the belt. Just remove the cover and slip a new belt on. This should improve results about a million times. Hope this helps. Happy vacuuming :)
p.s. dont hesitate to send me a follow up request if this doesnt help. That machine should work nothing short of amazing.
Aug 30, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Nothing is being sucked-up
then there is a clog in the hose somewhere
Jan 17, 2009 | Kenmore Progressive Bagless Upright with...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
Jan 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
