How do i not have my pointer automatically click on a item?
  • 691 Answers
Hello
Thank you for using
FixYa for your problem
Click start > my computer > tools > Folder options > general tab > click items as follows section > select the radio button for the option "Double-click to open an item (single click to select)"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Nov 18, 2009
How to Open Files and Folders in Single Click?
Go to pointer settings an search for click options
Oct 18, 2016 | Computers & Internet
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Jun 01, 2014 | Computers & Internet
I have just connected a quill mouse to my laptop. Right and left clicks work but you can't move the pointer.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
May 19, 2012 | Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
Cursor jumps all over the place. My husband is ready to throw the computer away.
See if you are using Enhance pointer precision,if so try and turn it off. Click Start, click Run, type control mouse, and then click OK. Click the Pointer Options tab, click to clear the "Enhance pointer precision" check box,click Apply and OK. If you are using a wireless mouse try changing the battery.You can also go to the mouse control in the control panel.Uncheck the options to "automatically move pointer to default button". Also check the sesitivity of your touch pad , if it set to a high sensitivity and you barely touch it , it could register as a double click.
Nov 17, 2010 | Samsung N150 (36725723009) Netbook
How to replace touchpad on Compaq Armada M700
  • “Hi, “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the "Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver, "Update Drivers, click Apply and (OK).
    Note: Restarting the computer will configure system changes.
    "Rating the solution is your way of letting me know if it (helped or not), thanks."
May 19, 2010 | Compaq Computers & Internet
My touchpad scrolling doesnt work. how can i fix it?
  • Hi, this Information apply to the same application for the "Mouse" and "Pointer Device" to function properly.
    I. “To “Enable” the "Mouse" or (Pointer Device) using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the "Mouse" or “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Driver” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver,” click (OK), this will ensure that the application take effect.
    Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
    "Rating the solution is appreciated, thanks"
Apr 12, 2010 | Acer Aspire 5335-2257 Notebook
When i move the pointer arrow it sometimes clicks on things automatically (without me clicking at all)...why is this?
Go to the mouse and pointer settings and change the one click open to double click options. It would be fine
Jan 19, 2010 | HP Mini 1000 Netbook
How do I shut off the pointer device on my HP pavillion laptop
Hi islandcustom, to shutoff the Pointer Device; Go to: Control Panel, in the Hardware and Sound category; click on (Mouse) Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (disable) this being the Pointer Device. Click the Disable button, just below. Be sure to (Click) on the Apply button! “ lastly click OK”. This will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Uninstalling) of programs, and or (Disabling) of Hardware, etc. Thanks paul7of9
Jan 06, 2010 | HP Computers & Internet
Computers & Internet Logo
David Payne
David Payne
