TV will not start easily. Akai LCT2721AD
Hi, TV will not start easily. Takes multiples (30+ sometimes) pushes of the power button (Akai remote or TV) to get the on light. When the on light comes on once, it takes another 10+ pushes of the power button for the TV to stay on. Akai LCT2721AD
Thanks for your help!
    Problem Solver:
  • 11 Answers
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Posted on Jan 02, 2010
I have 32" akai that won't turn on - it is plugged in
I had the same problem witht he same tv that was given to me! I just took off the cover to the DVD player and unpluged all the connectors to it and then the TV worked. Now you will not be able to use the DVD player but you can hook one up externally
Oct 23, 2009 | Akai LCT3201TD 32 in. LCD Television
Akai TV remote is not working correctly
I don't think the Akai remote is designed to work with cable or satellite service. I have to use both remotes & I have Direct TV.
Try unplugging the TV for a few minutes then plug it in and try the remote again. I had the same problem shortly before my Akai LCT2721AD quit working altogether. Three 1000uF capacitors blew in the power supply. Bought 3 new ones and replaced the blown ones myself rather than pay over $100 for a new power supply. Works fine now.
Oct 23, 2009 | Akai LCT2721AD 27 in. LCD Television
My Akai LCD TV/Dvd player will not turn on
http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Jun 17, 2009 | Akai LCT2721AD 27 in. LCD Television
Tv will not turn on with or without remote
The power supply is broken. You need to replace the capacitors that are bulging inside. I did and now it works fine. I don't have any experience but I did it. Follow what this guy did. http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Jun 14, 2009 | Akai LCT2721AD 27 in. LCD Television
TV will not come on by using the remote control
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Nov 17, 2008 | Akai LCT2721AD 27 in. LCD Television
AKAI LCT2721AD On/Off Problem
My Philips LCD TV had the same problem. If your Voltage system is 110 AC till 127 AC and no transformator, then it is probably caused by one of the 4 main transistors, which are likely not originalfrom AKAI, but made in Malaysia or closeby there.
My TV works perfectly after 1. Replacing the burned or semi-burend transistors (in the back panel) 2. After repair (=US 60 plug the TV in a outlet from transformator set to 100 V.Good Luck!
Apr 15, 2008 | Akai LCT2721AD 27 in. LCD Television
I can't program my universal remote to my tv
I found these codes for this Akai (in which I'm totally dissapointed) and successfully programmed my DirectTV remote using 11675. Good Luck,
Mar 18, 2008 | Tivo DirectTV Remote Remote Control
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Akai lct2721ad flashing red light
I would bet on the power supply....these (and other Akai LCD) are notorious for filter capacitors. Look for electrolytic capacitors with a dome-like bulge on the top of them. They are usually located at the top of the power supply board where the power output lines run out.
Hpe this helps you out....
Sep 23, 2007 | Akai LCT2721AD 27 in. LCD Television
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
Electro Med Services...
