Question about LG Vu CU920 Cellular Phone
Power shuts down and you cant turn the phone back on without removeing the batt then replaceing it. I have 2 new phone and it is happening to both.
  • mike Nov 18, 2009
    They are not refurbished. I recived them yesterday fully charge them and after a couple of hours the go out. When I remove then replace the batt. I still have a fully charged batt...
  • mike Nov 28, 2009
    Thanks for the reply. The phones came with a Kingston memory card. I found out that the phones don't like the Kingston. I removed the cards and no problems.
  • 61 Answers
I would contact your warranty center if you have had the phone less than a yr .. if it is a refurbished device warranty only covers through att for 90 days att warranty is 1-800-801-1101
Posted on Nov 18, 2009
  • Helen DiBari
    Helen DiBari Nov 28, 2009
    is it still within the first 30 days of purchase if so i would take them to an ATT store (not an authorized retailer) and swap them out .. if not you would have to go through warranty and they will send you a replacement but it will be refurbished! where did you buy the phones?
Vtech InnoTab2 will not turn on. Using adapter instead of batteries. May turn on briefly but then shuts off. Does same with fresh batteries. Only 1 year old.
try this: remove batts and all power source. remove cartridge. press and hold power button for 30 seconds. place batts back in the toy and try turning it on.
Mar 17, 2014 | VTech Communications INNOTAB 2 PINK
Please Tell me how to unlock aircel mobile digibee g225
1.call your provider 2.tell them about unlocking your phone 3. remove battery and sim 4.replace batt with no sim 5. type unlock code 6. remove batt and put sim back in 7.replace batt 8.apply cover 9.power on 10.YAAAY its unlocked.
Apr 24, 2011 | Cell Phones
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
I cant charge my camera. i connect it to the computer and nothing happens
Remember you need to switch the cam. on and all that you can see is a lamp on the cam which is blinking.
If you're still experiencing problems after that: Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or cable exchange.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 27, 2009 | Kodak EasyShare M883 Digital Camera
Sony vaio power up issue
hi
u carry out your laptop battery and then restart and if you find still problem, and want technician help contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Sony VAIO VGN-NR160ET Notebook
IPaq rx3115 working like PC not Pocket PC, need to plugin always
You need to purchase a new removable battery for your RX
The removable batts usually only last about a year (like cell phone batteries).
Although it is showing 100% charge, the battery is not storing enough power to run the ipaq
The rx series uses 2 batteries, one is the removable one u can see/access when u remove the back cover. The other batt is a small round batt which stores the basic info for your system (so you don't lose your data when u swap out the removable battery).
This small (backup) batt is similar to the cmos battery on a laptop or pc.
You cannot easily replace this, as the unit needs to be disassembled to access this batt.
If you are tech-y (and brave), the replacement button batteries are sold on ebay for $9-12
Normally, if your removable batt is bad, you could still use your unit plugged in, and could
remove from AC power without losing data. Not the case if your replaceable batt is exhausted.
When both batteries are bad, you lose everything when u remove unit from AC power.
My workaround without having to disassemble unit:
Purchase and fully charge new removable batt (They have huge capacity ones available for like $15 - better than the original !).
Load up all your programs & settings the way you like.
Perform full backup to SD card (& also on PC via active sync - to be safe)
Now the only time you should lose your data (like hard reset) is if you allow the battery
to completely drain, in which case you can restore your backup.
If you purchase 2 removable batts, you can easily swapout without losing data if you
use the usb charge cable & leave ipaq plugged in while you change battery
Hope this helps
Jun 01, 2009 | HP iPAQ RX3115 Pocket PC
Factory Alarm won't stop once battery is replaced
put your key in the door and turn the key to either direction!!
Dec 07, 2008 | 2002 Chevrolet Cavalier Coupe
MY LG ENVY KEEPS SHUTTING OFF
I had the same problem, it is because the metal parts on the battery arent staying on the metal parts of the phone! All I did was fold a small piece of paper, and put it between the battery, and the phone. It makes the battery fit tighter, so it wiggles less, and causes the battery to have a tighter connection to the phone. Kind of ghetto, but it works!!! If this dosent work for you just make the paper a little fatter.
Sep 03, 2008 | LG enV VX9900 Cellular Phone
Phone keeps shutting off
I have had the same issue. Verizon is replacing my phone.
Dec 08, 2007 | Cell Phones
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
