Question about Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis is leaking water severly from the back.
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
I have a Kenmore Elite Oasis HE top load. The machine sounds like a thunder when it spins, and also a pond of water leaks on the floor.
Check your hoses for leaks or possibly the drain it's draining in is clogged or half clogged or too clogged to accept large amounts of water all at the same time. Not to sure bout the thunder part. Lol
Jun 13, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite washer model # 110.24082200 is leaking from bottom. No visible leak from back panel acces...
my kemore whasing machine model10010 .25864400is not drain all c los left sam wather in dram and sound of water pamp like cenot turne tenks Bruno
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
KENMORE WASHING,wATER IS LEAKING FROM THE BOTTOM NOT THE HOSES
Possible circulation or drain pump leaking or associated hoses. See page 11 Oasis Tech Sheet
Jan 25, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
